Old 08-28-2016, 04:19 PM   #1
Peterborough , New Hampshire
half my electric is not working
The one thing I knew was OK in my new to me 1971 AS was the electric. I went in her the other night and the back half of the campers electric is not working. I checked the circuit breakers, they were fine, I turned them off and on again anyway. I unplugged and plugged back in. I could hear it connect. What else can I look for?
terricrowe26 is offline   Reply With Quote
Old 08-28-2016, 04:26 PM   #2
Agent 86
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
You need a test light or a volt meter to check and see if the circuit breaker is indeed closing.
If so, then you need to pull the outlets out and find the open circuit.
If the circuit breaker is not the problem, chances are the problem is going to be in one of the outlets where the circuit is "daisy chained".
Gradiens super tenui glacie.
Old 08-28-2016, 05:21 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
12 v DC OK?
Old 08-28-2016, 05:46 PM   #4
Nowhere , Somewhere
If it's the lights it's 12 volt. Check fuses.
avionstream is offline   Reply With Quote
Old 08-29-2016, 02:00 PM   #5
Lexington , Kentucky
Also check to make sure you are getting current on both legs of the 30/50 amp
circuit.
wlanford is offline   Reply With Quote
Old 08-29-2016, 05:26 PM   #6
2016 27' Flying Cloud
McDonough , Georgia
Hi - Similar happened to me in my 2016 FC - made no sense to me what was working and what wasn't. Fridge, TV & DVD player not working, their outlets not marked GFCI. Other stuff like microwave & fans OK. After messing with breakers, power cord, etc., decided to check for GFCI anyway.
After a bit of searching, found one lone GFCI outlet in bathroom - sure enough, it had tripped. pushed in button, all good again.
Doesn't hurt to check the simple stuff. Can't hurt; might help.
Kittycatcat is offline   Reply With Quote
Old 08-29-2016, 05:50 PM   #7
Nowhere , Somewhere
Not sure a 71 had gfci circuits.
Old 08-29-2016, 06:31 PM   #8
1999 30' Excella 1000
small town , Maryland
Make sure their is power leaving the breaker. Check the last working plug away from circuit board or the first dead plug. A screw or wire is loose somewhere between the two. Could be also the plug. Hope this helps. Please let us know what the problem is when you find it
streaminwild is offline   Reply With Quote
Old 09-03-2016, 08:12 PM   #9
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
If by back half you mean just the back ceiling lights...the wall mounted toggle switch just inside the entry door operates the back roof light. I thought my wiring was screwed to and when someone pointed that out I felt silly but I just didn't know before then :-) So hit the toogle switch on the wall and if the light doesn't come on go turn the operator on the back light fixture itself one turn and hopefully it's that simple for you to and you'll have light again. The reason they have the toogle by the door is for convenience at night so you can just click the switch in the pitch black of the night rather than feel your way around in the dark for the ceiling mounted light fixture
thesignlady is offline   Reply With Quote
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 4 04-03-2016 09:16 PM
Refueling: GASOLINE TANK- Half EMPTY or Half FULL? Ray Eklund On The Road... 33 06-12-2015 06:54 AM
Half polished. Half arsed.... gomotomoto Our Community 9 11-22-2014 04:41 AM
Only half of running lights working gmehal Lights - Interior & Exterior 12 07-04-2008 09:57 PM
