Old 10-10-2015, 07:31 PM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
http://www.noshockzone.org/generator...utral-bonding/
Brevi tempore!
Old 10-31-2015, 05:40 PM   #16
cmipilot
1975 27' Overlander
Flower Mound , Texas
Am I missing something obvious here or isn't modifying the "dog bone" going to require cutting off the factory end and replacing it to provide access for the jumper wire you're proposing?
cmipilot is offline   Reply With Quote
Old 10-31-2015, 07:45 PM   #17
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
No, you plug it into the spare generator receptacle.
However, IMHO, it is a total waste of effort, but I reserve the right to be wrong.
Brevi tempore!
Old 10-31-2015, 08:14 PM   #18
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Ground fault
Every time I fire up my Northern Tool 4000w electric start generator which is sitting on the ground, it triggers the ground fault breaker to trip on my Serenity.
My plan is to have the generator connected to a good ground, possibly a five foot heavy chain, or even a copper pole in the ground to see if this can be eliminated. It is frustrating to have to reset this each time I use the generator.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
