Old 08-06-2009, 08:28 AM   #1
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Question Ground fault circut breaker
My frig stopped working on A/C and during trouble shooting, found the bath area plug not working. I plugged the frig into another circuit and it works fine.
I then got out my trusty voltage tester and got voltage at both outlets. I don't know how much as the tester is a go - no-go lite and not a meter. If I open the ground fault circuit breaker, I lose the voltage on the tester. I then used my vacuum cleaner has a load and it would not run when plugged into either of the ground fault circuits even though the tester indicated voltage. I suspect a faulty ground fault circuit breaker?? ///any ideas?
I also discovered the out door receptacle is not on a ground fault circuit.
Pop Rivet is offline   Reply With Quote
Old 08-06-2009, 10:42 AM   #2
1971 29' Ambassador
Leonardtown , Maryland
A meter will tell you how much voltage you have. You may have enough to "light" the tester light, but not enough to run the frig. A low voltage condition may need some professional help.
I would get another Gnd fault outlet and see if you get same results.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Ground-Fault if Honda is grounded or not Driver1 Generators & Solar Power 19 07-11-2009 10:20 AM
Battery Drain in One Electrical Circut--72 Safari Airxtream Lights - Interior & Exterior 7 02-23-2009 12:24 PM
Control panel fault glh101282 Batteries, Univolts, Converters & Inverters 0 04-03-2007 10:50 PM
It's all Stef's fault... wahoonc Repairing/Replacing Floor &/or Frame 19 12-28-2004 10:01 AM
Power Steering Fault. canny_banjo_man Mechanics Corner - Engines, Transmission & More... 2 05-09-2004 12:17 AM
