Old 09-03-2016, 12:45 PM   #1
stephenb's Avatar
2011 25' FB Flying Cloud
Hutchinson , Kansas
Ground Bar
I'm installing a new converter/charger in my 2011 25fb. I'm supposed to put the green wire in the ground bar. Did I do it right?
stephenb is offline   Reply With Quote
Old 09-03-2016, 01:13 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Yes. Green is Neutral (ground)
Old 09-03-2016, 01:14 PM   #3
stephenb's Avatar
Hutchinson , Kansas
But is it connected to the ground bar?
Old 09-03-2016, 01:16 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Ground Bar
You did it right. But Green is "ground" not neutral. The buss bar above and to the right is the neutral buss. You have the label "ground bar" next to the neutral buss bar. The bottom bar with all of the bare wires is the ground bar, so if the green wire you show is from the converter you have it right.
Old 09-04-2016, 02:37 AM   #5
2007 22' International CCD
Ground Bar
IMHO, a More accurate term for the green wire is the British term: "safety earth"
Think of it as the safety ground that's there to protect you from miswiring.
It is NOT the same as the "neutral" wire. That is the "return" for the hot wire, and in an Airstream kept separate from "neutral". It gets tied together at the pedestal or outlet you plug into.
KE4GNK/AE
Old 09-04-2016, 07:51 AM   #6
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Yep! They are correct.
Old 09-04-2016, 09:15 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
If that green wire is the one you installed, you did connect it to ground.
The difference between those two bars is the way they are connected to the breaker box and their function.
If you look at the ground bar (the one with all of the bare copper wires) it is connected directly to the out going ground wires, the breaker box, and the incoming ground wire so that everything is grounded. This bar does not normally carry current, but offers a path for electricity to earth ground, when on shore power, in case there is an accidental short circuit. Earth ground is an electrode (copper rod) driven into the earth and connected to the shore power breaker box where neutral and ground are connected together.
If you look at the neutral bar (the one with all of the white wires) it is connected to a piece of plastic so that is isolated from ground. This bar normally carries current.
Alan
Demco Excali-Bar tow bar Denis4x4 Airstream Classifieds 0 05-03-2015 02:39 PM
grey bar and red bar compound capt ken Cleaning, Stripping & Polishing 4 10-03-2013 12:17 AM
19' Bambi ground clearance/"lifting" Glenn Hansen General Repair Forum 13 09-16-2007 08:11 AM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 07:11 AM
Ground bracket solution for awning yukionna Awnings 3 10-05-2003 10:09 AM
