Old 09-22-2016, 07:35 AM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
grey stick-on wire clips
You know those grey self-stick wire clip thingies that they used in the 70's to hold wires (and other stuff) against the inner skins? after 45 years, some have gotten brittle and broken; I need some solution for replacement on some, and for running new wires. (skins out--walls bare--full monty).
I haven't been able to find anything similar to these on various searches...wondering if anyone has a source, or a recommendation for some other wire-retention solution (that doesn't require poking a hole into whatever its attached to).
The only thing I can find that looks similar (in function) is these square stick-on things at Lowes...they have a raised center with slots that accept a wire tie.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-22-2016, 08:22 AM   #2
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
I got some of these. They work fine against the inner skin or on a layer of thin prodex insulation:
And these:
There are other options as well.
youngpeck is offline   Reply With Quote
Old 09-22-2016, 08:27 AM   #3
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Chuck:
VTS has them for sale:
http://www.vintagetrailersupply.com/...-p/vts-118.htm
You can also go to amazon and do a search for cable clips. I purchased some from them. However, I ran out and then used foil tape for some areas - in the middle 2 inches or so of the foil tape, i put the tape backing over the sticky side of the tape so the wire is still allowed to slide and move.
Greg
Greg1410 is offline   Reply With Quote
Old 09-22-2016, 08:56 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
How did I miss that??!!! (/face-palm) I just put in an order last night, too. nother shipping change.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 09-22-2016, 09:03 AM   #5
youngpeck's Avatar
1976 25' Caravanner
Great idea using the foil tape!
What gauge wire to run to new Horst grey tank sensors? chilipepper Plumbing - Systems & Fixtures 0 06-24-2014 11:36 AM
Grey wire??? Fuse panel izzyashdown Electrical - Systems, Generators, Batteries & Solar 5 09-21-2013 12:04 PM
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 07:47 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 06:27 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
