Old 06-18-2013, 04:19 PM   #1
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Going Solar
In my ongoing quest to create trailer perfection (!), SilverLeaf will soon have a solar installation. While rooftop real estate is precious, there's room for three 100W panels, and my calculation is that 300W will be adequate. Beyond that? That's what the two Honda 2000's are for. Really excited about this next project. Also glad that I didn't bite on the A/S solar package when I ordered my trailer, as the package I ordered from AM Solar will give me a lot more for my $. I installed a Trimetric a year ago, so that'll compliment this next project. And, a special thanks to Lewster for all of his suggestions with my electrical projects. Ordered two Lifeline AGM's from my local battery store on Monday. Once this install is complete, I'll be taking a L-O-N-G voyage...either Nova Scotia or Banff. Hmm, maybe both?
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-18-2013, 04:22 PM   #2
rowdyATX's Avatar
1956 26' Cruiser/Overlander
1961 28' Ambassador
Keep us updates on the installation and send pics. I'm doing a shell off now and would like to install panels!
rowdyATX is offline   Reply With Quote
Old 06-18-2013, 04:33 PM   #3
BAB
BAB's Avatar
2015 30' Classic
Will do. Gotta pay it forward for all the help I've had. I spent a LOT of time reading about what other folks had done before I decided to do this. AM Solar also has a terrific website, and there are several YouTube videos that make this look less intimidating. Still deciding whether I'll rivet the brackets onto the roof (with ample amounts of Vulkem), or use stainless steel screws. Right now, I'm leaning towards the rivet option.
_________________
ProPride 3P
AIR# 58452
Old 06-18-2013, 05:02 PM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
There are stainless rivets... big stainless rivets
Old 06-18-2013, 05:32 PM   #5
timmaah's Avatar
1999 25' Safari
On , the road
The 3m tape and dicor provided by AM Solar has been working great for us.
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 06-18-2013, 05:58 PM   #6
pbearsailor's Avatar
Port Hadlock , Washington
Been very happy with the tape on mine as well for over two years now.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 06-18-2013, 06:24 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
DON'T PUT HOLES IN YOUR ROOF !!!!!
I have had solar panels on my service vans since 2005 and all are held on with 3M VHB tape that is provided by AM Solar. They have NEVER lifted, budged or moved in any way. In fact, when I got my current service van (see avatar), it took all I could do to remove the old mounting feet to transfer the panels!
YOU DON'T NEED ANY MORE HOLES IN YOUR ROOF!!!!!!!
Old 06-19-2013, 04:31 PM   #8
BAB
BAB's Avatar
2015 30' Classic
I got the message. I have some of the 3M VHB and have used it liberally in all kinds of places....it is great stuff. Oh, and A/S uses it inside the clearance lights to seal them to the housing. I found this out when I was hooking up my Voyager WiFi rear view camera and had to tap into 12V from the center clearance light on the rear of my trailer. I didn't break the plastic, but that tape does NOT let go. So, I'll use it on the panels.
_________________
ProPride 3P
AIR# 58452
Old 07-25-2013, 10:50 PM   #9
El Gitano's Avatar
Salem , Oregon
BAB, what number VHB tape have you used? I was out at the 3M site and there are quite a few choices. I'm thinking of doing some solar myself and not crazy about drilling hole in my roof. Thanks.
* 2007 International Custom David Winick #16 *
El Gitano is offline   Reply With Quote
Old 07-25-2013, 11:46 PM   #10
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
BAB,
We have a 27FB and were able to fit 4 of the standard sized 100w AM solar panels, 3 on the curb side and 1 on the street side. I think we could have shoehorned in a 5th panel by using the smaller, higher efficiency 100w panels that AM Solar sells. I know the 28 is a rear bed setup and that it probably has a very different roof layout than mine. IMHO having 400w is the way to go if you can fit them on the roof and worth the added expense of the smaller 100w AM Solar panels. Good luck on the instal, you will love the freedom of solar.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 07-27-2013, 07:53 PM   #11
lewster's Avatar
The last 28 that I put solar on had 8 of AM Solar's GS-100 panels. It was quite a set up.
Old 07-27-2013, 07:54 PM   #12
daveswenson's Avatar
Issaquah , Washington
Wow! What did they have for batteries?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 07-27-2013, 09:07 PM   #13
lewster's Avatar
4 Lifeline GPL-6CT 300 amp/hour XL golf cart batteries for a 600 amp/hour battery bank and a 2800 watt Magnum MS 2812 pure sine wave inverter/charger..........and a bunch of other goodies! Took a solid week for the installation.
Old 07-27-2013, 10:17 PM   #14
Scott J-24's Avatar
Wow, that is quite a setup!
WBCCI #1215
Air #54601
