Old 07-29-2013, 06:42 PM   #15
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Where did you mount the batteries?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 07-29-2013, 06:46 PM   #16
lewster's Avatar
Naples, FL , Hood River, OR
Under the front goucho
Old 07-29-2013, 07:31 PM   #17
BAB
BAB's Avatar
2015 30' Classic
Greensboro , North Carolina
First Use Report: Just back from two weeks: Vermont, New Hampshire, Maine. My AM Solar panels worked great. Though I had hookups most of the time, it is WAY cool to be driving for a good part of the day, then look at the meter and see that my Lifeline AGM's are at 96% when I arrive. Coupling those with the new 2000W Inverter made a big difference in my enjoyment of my trailer. BTW, don't see how I could get more than 4 panels on my roof, at least of the same size I installed!)
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-30-2013, 03:57 PM   #18
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
BAB, I just did a couple of weeks out west, no hook ups, and was at 100% every day by noon. Fridge and WH on propane. We watched TV every night and used the electric coffee pot in the AM. We left the 1500 watt inverter on all the time except when under way. 4 AGM batteries and 300 watts of panels. You may wish to check your hook up to see why you were at only 96% by days end unless you were just having typical east coast weather. Rain, fog, wind, followed by rain, fog, and wind. And salt. Don't forget to wax her up again. Jim
Jim Flower is offline   Reply With Quote
Old 07-30-2013, 04:32 PM   #19
BAB
BAB's Avatar
2015 30' Classic
Pretty sure I'm getting plenty of panel output, haven't had much "full sun" -- and talk about thunderstorms through NJ and PA! I promised some photos of the install, so here they are. Mounted the controller and breaker (between panel collector and controller) in the empty panel at the bottom of my wardrobe. Remote is mounted up front with my other electronics.
ID:	192079   Click image for larger version
ID:	192081   Click image for larger version
_________________
ProPride 3P
AIR# 58452
Old 07-30-2013, 06:34 PM   #20
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
I had a bit of sun advantage since in Alberta it gets dark about 10:30 PM and the sun rises at 4:30 AM. It looks like you are most likely OK given the nasty weather. Great install. Jim
Old 07-30-2013, 06:54 PM   #21
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
Originally Posted by lewster View Post
The last 28 that I put solar on had 8 of AM Solar's GS-100 panels. It was quite a set up.
That 28' has been from Key West to Niagara Falls since Lew 3M taped those 8 panels on ... zero issues!
UAPachyderm is offline   Reply With Quote
Old 07-30-2013, 07:25 PM   #22
lewster's Avatar
Good Thing!
Old 07-30-2013, 07:53 PM   #23
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
was wondering what the black round thingy on roof are?? why .. was trying to figure out how you get 8 panels on roof with out stacking them on top of each other..
I can see a place for 7 from the picture of babs AS.
I also have to ask the 4@100 watt panels trying to keep up how much battery capacity??
what is rule of thumb on solar. I have been tying to get a handle on that.
In the 8 panel deal lewster was talking about they were keeping up some 600 amp/h of battery so just figuring 100 watt panels you are over watts to amp/h some what.. is the "golden rule" double watts to amp/h or how is that figured.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 07-31-2013, 05:45 AM   #24
lewster's Avatar
It really depends on your usage of the power to get it right, but the 'rule of thumb' that many follow is 1 watt of solar array for each amp/hour of battery capacity.
You can, of course, have as many panels as your roof can hold and have extra solar capacity, which will provide more charging amps to the batteries and keep them at a higher state of charge and provide for faster recharge cycles.
Old 08-29-2013, 02:32 AM   #25
rowdyATX's Avatar
1956 26' Cruiser/Overlander
1961 28' Ambassador
When should I consider details on wiring for solar panels? My shell is off and my frame is finally repaired. Since it is taking me longer than expected to find ( figure out) holding tanks, is there any wiring I can start doing now while the frame is uncovered in preparing for solar panels, or in preparing for anything else?
rowdyATX is offline   Reply With Quote
