Old 07-15-2016, 04:05 PM   #1
In Over My Head
1975 Argosy 24
Going Shore powered Only...
So my wife and I have recently purchased an Argosy 24 and I am in the process of setting it up as a mother-in-law suite in back of the house. When I purchased it, the interior had already been gutted (no plumbing, no electrical, etc.) and there didn't seem to be any reason to keep a 12v system until today...
I have a Dometic Penguin II on the way and the thermostat that goes with it will only run on 12v. Dometic hasn't been much help other than confirm that the thermostat requires 12v. I was hoping that someone on here can confirm for me that I can simply hard wire in a step down transformer/reducer and still be able to use the thermostat.
Thanks! Sometimes I feel like I am in over my head...
FarmerJon is offline   Reply With Quote
Old 07-15-2016, 04:18 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The thermost at at my house is low voltage 12 volt. A small transformer is mounted on the wall above the inside CK breaker box. It powers the thermostat and the door bell. I would suspect it is the same in most homes.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 07-15-2016, 05:23 PM   #3
Trnpk Crsr's Avatar
Baltimore , Maryland
A transformer will only supply 12 volts AC. If the thermostat requires 12 volts DC, you will need to find a way to rectify the AC to DC.
Trnpk Crsr is offline   Reply With Quote
Old 07-15-2016, 05:54 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Find an Airstream owner who has upgraded their 'battery burner' Parallax converter to a new 3-stage unit.
It will provide you with a continual supply of '12VDC' which is actually 13.6 VDC and makes for a perfect DC power supply. No batteries required!!!
Lew Farber...RVIA Certified Master Tech...ABYC Certified Master Marine Electrician
SOLAR TECH ENERGY SYSTEMS, INC.
AM SOLAR ...MAGNUM…VICTRON ENERGY...LITHIUM & LIFELINE BATTERIESMARINE REFRIGERATION
lewster is online now   Reply With Quote
Old 07-15-2016, 10:18 PM   #5
In Over My Head
1975 Argosy 24
Lewster, that sounds like a great solution! Do you know anyone who has one lying around?? Or a recommendation on where to find one??
Old 07-15-2016, 10:36 PM   #6
lewster's Avatar
PM sent!
Old 07-15-2016, 11:41 PM   #7
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
12VDC wall plug power supplies "bricks" are readily available. PM me I can send you one. We use them in our products. Look on www.DIGIKEY.com or Amazon. Great selection.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 07-15-2016, 11:49 PM   #8
2015 30' FB FC Bunk
Golden , Colorado
http://www.digikey.com/product-detai...455-ND/3094981
Old 07-16-2016, 09:06 PM   #9
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
or this...
and if my pix didn't show up, it's an ac to dc adapter. Two prong ac plug on one end and cigarette outlet on the other.
StreamDog is offline   Reply With Quote
Old 07-17-2016, 08:55 AM   #10
In Over My Head
1975 Argosy 24
Thanks for the plug in ideas. I think I am going to go with something that I can mount behind the walls or in a panel somewhere. I am probably going to go with Lewster's suggestion and install a parrallax to run any 12vDC applications that come up!
Old 07-17-2016, 12:13 PM   #11
DKB_SATX's Avatar
1975 Argosy 24
1976 Argosy 28
Alamo Heights , Texas
Remember that all of the wiring for lighting (and the lights themselves if they're still installed, you didn't say how "gutted" the trailer is) are 12V, so it's useful to have a 12v source to run the built-in lighting, otherwise you'll have to have lamps which take up valuable space. A cast-off Parallax converter as Lewster mentioned would be a good source that should be cheap/free from someone who just wants to be rid of it.
— David
Il Carriaggio — 1975 Argosy 24 | Il Progetto — 1976 Argosy 28 Center Bath | WBCCI# 15566
Old 07-17-2016, 01:32 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Of course you know you still need a 12 volt battery and charging system to run the brakes if you ever pull the trailer? and 12 volts to run the lights, water heater, and refigerator? and the vent fans? Shore power only to me would still include a converter and batteries.
Yes, you probably can go all 110 with complete rewiring and non RV appliances if you never are going to pull it. You will probably need the interior skins off to do a decent job of that.
Old 07-17-2016, 03:04 PM   #13
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Maybe I'm overthinking this, but couldn't you simply use a cheap 12V adapter? I got to have thirty of them laying around from various junk appliances.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is online now   Reply With Quote
Old 07-18-2016, 08:47 AM   #14
In Over My Head
1975 Argosy 24
Since it is fully gutted (skins removed, wires stripped, plumbing removed, no insulation, new subfloors) there are no electronics or lighting from the original (except the stove fan). I am working from square one here! In some ways that is nice, as I can have it exactly how I want it, but it is difficult that I have nothing to look at and base decisions off of.
I am trying to get my hands on a parallax to run things that are trailer specific like the thermostat, AC Unit, Fan, and maybe a few lights.
I think I would rather have one large, central inverter than to have lots of small ones in the wall.
And I don't have any intention to pull this anywhere until i am selling it, so I am not really concerned about the break away brakes.
Thanks again for all the ideas and thoughts! It has been very helpful!
How many amps going to batteries on shore power? phann Batteries, Univolts, Converters & Inverters 16 01-25-2016 08:41 PM
Are "Airstream Only" Parks Really "Silver Only"? JimGolden On The Road... 28 08-22-2015 11:58 AM
Rear AC receptacle only works on shore power paullovern Sprinter and B-van Forum 17 09-02-2014 12:31 PM
Going to 110v only hockeyrink Electrical - Systems, Generators, Batteries & Solar 11 09-03-2008 10:24 AM
