Old 09-20-2016, 08:42 PM   #1
LittleLucy's Avatar
2002 19' Bambi
Bowdon , Georgia
GFI outlets not working on Bambi
After camping in heavy rain the outlets labeled GFI on the schematics are not working....the others are. None of the outlets have GFI button to reset.
Didn't find a switch in the fuse box.
All else is working fine.
It is a 2002 Bambi 19'
Where else do I look? Thanks!!
LittleLucy is offline   Reply With Quote
Old 09-20-2016, 09:09 PM   #2
New Borockton , Alabama
Images: 21
GFI outlets get finicky in wet weather, after all that is kinda their job but you should be able to reset it once it dries out. It's a leak to ground if you want to read how they work. You said, fuse box but maybe mean't breaker panel box? It won't be in the fuse box. Not sure on the 02 models if you have a all in one power center like the 7300 series or separate AC and DC panel which is most likely.
I'm sure somebody with a 02 model will chime in.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 09-20-2016, 09:57 PM   #3
LittleLucy's Avatar
2002 19' Bambi
Bowdon , Georgia
Found out where the breaker panel is located ....under wood panel below wardrobe. You know the one that falls off when traveling. 😊 Will try to reset tomorrow when back at camper. Should be dry as the rainy trip was in April.
Old 09-20-2016, 11:28 PM   #4
Images: 21
Best to have it looked at and see if moisture is getting near it.
888-828-1893
Bestconverter.com
Old 09-21-2016, 12:28 AM   #5
2007 22' International CCD
Check your outside outlets for water. They are on the GFI as well. If one got wet, it will pop the GFI for sure.
Old 09-21-2016, 02:34 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
In our 06 Bambi the breaker panel is below the closet next to the vanity. We trip the GFCI every time we wash the Bambi ... That means its doing its job! It's not enough to just push the reset button on the breaker..you have to toggle the breaker completely down to the off position and then back all the way up (on). Good luck!
TB & Greg and Abbey Schnauzer
#3954
Old 09-21-2016, 06:03 PM   #7
LittleLucy's Avatar
2002 19' Bambi
Bowdon , Georgia
Thanks all! Reset pressed and breakers toggled. All outlets working now. Feel that water was from blowing rain while outlet cover was opened, so not to concerned about where it came from but if reoccurring I will get it checked.
Getting ready for fall camping!
Old 09-21-2016, 07:25 PM   #8
65CV's Avatar
Western , Massachusetts
My son surprised me with the following statement when coming back from one of his Master Electrician classes: "A GFI protects the circuit, an Arc-Fault, Ground Fault Interrupter protects you."
At the very least, I will never try to bypass a GFI fault!
65CV is offline   Reply With Quote
Old 09-21-2016, 08:07 PM   #9
mandolindave's Avatar
From what a few electricians have told me
There are sort of three generations of GFI outlets ( or circuit breakers )
The first generation are prone to failure, especially now as they are aged. But they weren't the greatest when they were new.
The second generation were of better quality.
The third generation are VERY sensitive. Sometimes even plugging in a lamp that is turned on will trip them.
Please add to or correct me if I am wrong. I am not an actor but I play one on TV.
mandolindave is offline   Reply With Quote
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 10:15 PM
All outlets not working NicheVintage Lights - Interior & Exterior 11 09-16-2011 11:42 AM
Help - I'm tripping (GFI outlets that is)! 61Ambassador Electrical - Systems, Generators, Batteries & Solar 5 08-23-2011 09:55 PM
GFI, adding more outlets and cable TV... Airslide Lights - Interior & Exterior 0 10-18-2009 07:13 PM
Outlets not working - 74 tradewind pamelake Electrical - Systems, Generators, Batteries & Solar 14 03-31-2009 05:20 PM
