Old 10-30-2019, 08:11 AM   #1
2004 22' International CCD
Leander , Texas
GFI circuit malfunction
Hey y'all, I've searched for answers but no luck. I have a 2004 22' International CCD, and all of my GFI receptacles have gone dead. The GFI breaker was tripped and wouldn't reset. The new one does not trip, but there is still no electricity at any of the protected receptacles. Next I connected the wires to an adjacent regular breaker to see if maybe the new GFI breaker was defective...still nothing at the receptacles. My plug in receptacle checker shows no indication of anything good or bad, all outlets on the circuit, inside and out are dead.
AHappyCamper is offline   Reply With Quote
Old 10-30-2019, 09:47 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The outlets are typically “daisy-chained” i.e. the wire from the breaker goes to the closest outlet, then to the next, etc. Turn the breaker off and pull the closest outlet. Inspect it for loose wires. If that one is OK, check the rest.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-30-2019, 09:54 AM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
One really odd issue: You can get the wire into a breaker into the wrong part of the unit. The screw tightens down just fine. The wire isn't connected to anything at all. With power off, give it a good pull to see if this is the case ......
Second possibility: some of these breakers only reset properly if there is power applied. With power on, cycle the breaker (on - off - on ) and then recheck your outlets.
Problem connecting to home GFI circuit stahlhutdp Electrical - Systems, Generators, Batteries & Solar 27 09-14-2019 06:47 PM
gfi circuit breaker pops Lido&Linda Batteries, Univolts, Converters & Inverters 7 04-29-2017 12:22 PM
GM truck antilock brake malfunction dwightdi Tow Vehicles 20 03-13-2006 05:38 PM
345 LP Tank Gauge Malfunction cooperhawk LP Gas, Piping, Tanks & Regulators 1 12-06-2005 02:36 PM
water heater malfunction--help! ready to depart for xmas trip! susanborck Water Heaters, Filters & Pumps 23 12-22-2003 11:31 PM
