Old 04-02-2015, 12:49 PM   #1
the plains , Virginia
GFI Breaker
I have a 2007 Safari SE 25 FB. The GFI breaker in the panel under one of the twin beds seems to trip on a fairly regular basis. It controls the outlets and the refrig in the back/kithen living area of the trailer. Sometimes it will reset easily and other times it won't. Does anyone have experience with this. What might be causing it to trip repeatedl? Does it need a new breaker? Can i just remove the panel cover, pull the old breaker out and snap a new one in or is there more to it than that? Thanks.
jdcamp is offline   Reply With Quote
Old 04-02-2015, 12:52 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Check for moisture and dust in the breaker box and all the outlets. I believe your trailer should have an outside outlet, which would also be on the GFCI circuit. That is a frequent source of nuisance trips. Compressed air helps blow out any dust and cobwebs.
Old 04-02-2015, 01:26 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
GFCI may be doing you a favor!!! Shut off power, Inspect outlets and dry well...canned air works best...but remember, electricity CAN flow over gas jet...remember, no power!!
Is AS outside or in covered shelter?
I removed my external outlet and replaced to fix our "intermittent" issue.
Remember, power off!
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-02-2015, 01:32 PM   #4
daveswenson's Avatar
2012 28' International
Issaquah , Washington
It's also possible that it is the breaker itself that's going bad. They're easy to replace.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
GFI breaker tripping TomS Lights - Interior & Exterior 10 02-15-2015 05:58 PM
20 Amp GFI breaker blows when plugging in New IOTA Converter Tartimisi Batteries, Univolts, Converters & Inverters 7 05-03-2013 03:07 PM
DAMN GFI Breaker dan50w Lights - Interior & Exterior 13 12-24-2009 12:59 PM
Lifespan of GFI breaker? blickcd Lights - Interior & Exterior 7 07-07-2009 11:23 AM
GFI breaker keeps tripping. Van Electrical - Systems, Generators, Batteries & Solar 10 08-06-2005 11:33 PM
