Old 07-23-2016, 01:35 PM   #1
ptv
pv
2008 23' Safari FB SE
st. aug. , Florida
gfi
I've got 3 dead outlets in my 08 safari, all say gfi protected? all fuses good, where is the gfi???
pv
ptv is offline   Reply With Quote
Old 07-23-2016, 02:07 PM   #2
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Gfi
The GFI should be built into one of the breakers in your main A/C panel (where the A/C breakers are located and probably the DC fuses also).
There is probably a small white button on the breaker that will need reset. You should try to determine the cause of the fault prior to resetting. If it will not stay set your have a ground fault somewhere on one of the connected circuits - obviously....
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 07-23-2016, 03:18 PM   #3
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
gfi
Actually most RV gfci outlets I have seen have their set/reset button in the outlet(s) themselves, and are served with a standard breaker feed.
You will also most likely find one "control" gfci outlet in the bath or kitchen, with others "daisy-chained" downline controlled by the "master". Look for the one with the reset button, and if it won't reset, replace it.
Gfci outlets usually fail once the control circuit does it job enough times, or just from dampness and age...... Turn off all power and replace the gfci control outlet exactly as it is wired now (important), or even better, have a licensed electrician do it.
Hope this helps.
ShinyPete is offline   Reply With Quote
Old 10-03-2016, 02:50 PM   #4
2009 22' Sport
La Jolla , California
I am having the same problem with my 2008 22 Sport. The manual says that there are 4 type 2 thermal breakers located under the front bead. Are these just switches or do they have brass buss bars that look like big fuses?
Barwise is offline   Reply With Quote
Old 10-03-2016, 03:35 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My 2006 Safari uses a central GFI in the main panel. The wall sockets are not individually protected and have no separate test button.
MICHAEL
Old 10-03-2016, 04:03 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
This is a link to the 2008 Safari manual. Page G-14 shows that there is a ground fault breaker and how to test and reset it.
https://www.airstream.com/wp-content...safari2008.pdf
Alan
Old 10-03-2016, 04:06 PM   #7
richw46's Avatar
Lexington , Kentucky
In our home's master bath there are 2 plugs, one on each side of the vanity. One day they both stopped working. Checked all the breakers, then went out and got one of those signal generator tools to trace the wiring. Up the wall, across the ceiling, up in the attic I went across the house and down a wall. Came out of the attic and into the upstairs bathroom where there was a tripped GFI. That was 12 years ago. I just checked with the wife, she remembers where they go too .
I'd check the outlets and the master breaker box.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-08-2016, 12:27 PM   #8
2009 22' Sport
The 2008 22 Safari only has one gfi breaker, it's on the main 7300 panel. I replaced it ($44) and problem solved. Thanks again.
Dometic RM100 tripping GFI tschat Refrigerators 3 08-21-2006 10:01 PM
GFI breaker keeps tripping. Van Electrical - Systems, Generators, Batteries & Solar 10 08-07-2005 12:33 AM
GFI Tripping grizzy Electrical - Systems, Generators, Batteries & Solar 3 09-07-2004 07:17 PM
A/C Blows GFI in Home Jenturnr Our Community 3 07-27-2004 08:39 PM
Gfi markus Electrical - Systems, Generators, Batteries & Solar 4 01-28-2004 09:23 PM
