Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-28-2009, 05:31 PM   #1
adonh's Avatar
Profile:  1976 31' Sovereign
Missouri City , Texas
Airstream Registry
GFC 110 outlets
Would a 1976 Airstream be equipped with ground fault circuit protection.
Don
adonh is offline   Reply With Quote
Old 04-28-2009, 06:08 PM   #2
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 234
Originally Posted by adonh View Post
Would a 1976 Airstream be equipped ...?
'78 Sovereigns were - the Univolt-Bath-Bedroom 110 circuit was protected by a panel mounted GFIC.
I have replaced the GFIC (expensive) and cleaned most of the recepticals - I am STILL vexed with phantom ground faults tripping the circuit. Most come just after someone has taken a shower - may be a humidity related thing....
Any suggestions for a permanent GF fix would be appreciated.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 04-28-2009, 07:22 PM   #3
Minno's Avatar
Profile:  1972 31' Sovereign
Lexington , Minnesota
I had a GFCI tripping problem in a sob trailer. Turned out to be the black (hot) wire running to two of the outlets had cut insulation, most likely caused when the trailer was built. Found the first one in the outside outlet, and then pulled the remaining outlets to check them just to be safe. That's when I found the second cut black insulation. I mean the insulation was missing from one side of the black wire for about a 1/2 inch inside the outlet box. One suggestion would be to pull all of the outlets on the circuit and inspect the wires closely - especially where the outside shething was cut away. Cuts or cracks in the insulation may be enough to cause the GFCI to trip when the humidity goes up. Another solution would be to replace the outlets in the GFCI circuit. Age can cause corrosion, again leading to the GFCI to trip in humid conditions.
Chris
12-volt outlets Steve & Susan Lights - Interior & Exterior 1 09-17-2008 06:21 AM
110V outlets cookeville34 Electrical - Systems, Generators, Batteries & Solar 2 09-17-2006 07:15 AM
110 outlets cracked dmadam Electrical - Systems, Generators, Batteries & Solar 1 09-15-2006 03:45 PM
warm outlets markus Electrical - Systems, Generators, Batteries & Solar 5 11-29-2003 04:06 PM
Use household 110 Outlets? mcostanzo Electrical - Systems, Generators, Batteries & Solar 5 06-26-2003 10:30 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
