Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 01-28-2007, 08:44 AM   #1
Joe1261
Profile:  1973 31' Sovereign
Union , Kentucky
Getting ready to order a Power Converter
Good morning,
Ok I am about to order a power converter for my 73 31' Sovereign, I was checking out the one on Vintage Airstreams web site. The 60 amp Progressive Dynamics INTELI-POWER 9260CV , also I was going to order the 12 Volt DC fuse panel to go with it.
I havent taken out me Univolt yet,,,, to darn cold Here in Northern Kentucky.
What I am asking is ... am I making the right choice on my purchase?
thank you
Joe
Joe Ledford
1973 31' Sovereign LandYacht
Joe1261 is offline   Reply With Quote
Old 01-28-2007, 08:51 AM   #2
rickandsandi
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Originally Posted by Joe1261
Good morning,
thank you
Joe
Joe -- the sixty amp unit should definatly cover you since you can only bring 50 amp into your AS!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
rickandsandi is offline   Reply With Quote
Old 01-28-2007, 10:47 AM   #3
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
The 60 amp converter is referring to 12volt amps not the 110volt feed amps If you are planning on running a lot of 12v items (lights, stereo, entertainment system, furnace, vent fans, fridge, etc) off the converter you might need even more. FWIW my 70's vintage came with a 40-45 amp converter. I do plan to replace it with a 60amp. I am not sure but it may also have a bearing on how much power can be dedicated to recharging your batteries too.
Aaron
WBCCI #2449 AIR #2495
wahoonc is online now   Reply With Quote
Old 01-28-2007, 10:58 AM   #4
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Good morning,
thank you
Joe
Yes, that is a good selection. I have the 55 amp Intellipower and it does everything I ask of it.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-28-2007, 11:11 AM   #5
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
Aaron is exactly right...30 or 50 amp AC service has nothing to do with DC output of the converter.
A good rule of thumb we use is length of RV and number of batteries you plan to charge, assuming there are no excessive aftermarket DC accessories like huge sound systems.
With all new converters, all of the rated output is available for charging, less whatever DC load you have running. For a shorter RV, maybe 19-23 feet and one battery, 35 to 45 amps is all you will need. 23-31 footers would probably benifit from the 45 to 65 amp models, If you have two batteries, lean toward the higher amp side. One important note however is the converter to battery wiring needs to be rated for the amperage if you go with a larger unit.
Old 01-28-2007, 11:23 AM   #6
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I have the 45 amp with charge wizard. Seems to work just fine, but I do not have any "phantom loads" in my unit. Just lights, fans, radio and furnace.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 01-28-2007, 11:46 AM   #7
chapparel
chapparel's Avatar
Profile:  1965 22' Safari
1965 22' Safari
Three Rivers , California
Hi Joe,
Could you please direct me to the site that you are ordering the items from? I looked at the Vintage Airstream site and could not find the place you mentioned. Thanks.
Chapparel SOTF, we have more fun than anyone.
chapparel is offline   Reply With Quote
Old 01-28-2007, 04:14 PM   #8
Joe1261
Union , Kentucky
Chapparel,
I am sorry I mentioned the wrong website. it is vintagetrailersupply.com
Joe Ledford
Old 01-28-2007, 04:30 PM   #9
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Take a look at a complete power certer it has the 12V and 120 all in one.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 01-28-2007, 06:15 PM   #10
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Chapparel,
Also try Randy's site: www.bestpowerconverter.com. He is very knowledgeable in his products and a nice guy too. I believe that he gives the Forum members a discount too.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
External Power Cord Replacement jstaad Electrical - Systems, Generators, Batteries & Solar 3 01-23-2003 07:16 AM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 01:59 PM
New power Convertor HOT! silverbullet Electrical - Systems, Generators, Batteries & Solar 4 09-24-2002 11:01 AM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 03:51 PM
test
