Old 12-16-2018, 05:41 PM   #1
Sheridan , California
Generators
We're getting ready to buy a Honda 2200i generator, mostly for home emergencies but also for camping. We have a 16' Sport with a single 83 amp/hour battery. Does anyone know approximately the length of time it takes to fully charge a single battery from say a 12.4 volt charge?
Airabel is offline   Reply With Quote
Old 12-16-2018, 06:18 PM   #2
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Several items to consider here.
First, you don't want to completely charge a battery with a generator. You want to "Bulk" charge the battery to 80 or 90% (until bulk charging stops) and then turn off the generator when it starts the Absorption stage. It is not very efficient to completely charge a battery with a generator. To bulk charge a battery from 50% to 90% takes a few hours, to take the battery to 100% may take five more hours. Five hours of generator run time for that last 10% is not efficient.
Next, to bulk charge my 230AH battery bank with a PD4655 converter with a 14.4V "Bulk" stage stage typically takes four to five hours. Your single battery may only take about two hours.
Then, the next issue is to determine if your converter has a 14.4V "Bulk" stage. The stock converter in my 2017 only charged at 13.6V. Therefore I replaced my stock charger with a PD4655VL that has a 14.4V Bulk stage and a light that displays which stage its in, so I know when to stop generator charging after the efficient Bulk stage is complete.
2018 Globetrotter 27Q, 32 nights 4,935 miles, 600W Solar, PD4655L, Duracell EGC2 Batteries, ProPride, 16" Michelin's, Champion 3400W Dual-Fuel, 2019 F250
Sold: 2017 Flying Cloud 25FB, 316 nights 40,150 miles, 400W Solar
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 12-16-2018, 06:54 PM   #3
AirMiles's Avatar
Think of the stages of charging a battery as filling a beer mug. In the first stage (bulk stage) you quickly pour the beer until the head fills the mug. Then you slowly add beer (absorption stage) as the head turns to beer. And finally, you could add beer to the mug as it evaporates (float stage).
Bulk stage quickly puts a lot of beer into the mug and absorption stage only puts a trickle of beer into the mug. Bulk stage quickly puts a lot of Amps into the battery and absorption stage only puts a trickle of Amps into the battery.
Old 12-17-2018, 12:26 PM   #4
Msherw's Avatar
2018 22' Sport
Blue Sky Ranch , Texas
Great analogy AirMiles. The only way I would use a genny to charge batteries is via the 120VAC input to the AS and the onboard system. A constant input of 13.2 with no absorption or float is likely to cause a good battery to fail prematurely.
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
Ham Radio Call sign K5FT
WBCCI #18673 - of Texas group
Msherw is offline   Reply With Quote
Old 12-17-2018, 03:00 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
No, I do not know. I plug my trailer into the generator and use the converter to charge the battery. Much simpler, faster, and I think better than fooling with the 12 volt generator output. The converter fast charges when the battery is low and then tapers as it gets charged. I do not think the battery will even charge at 12.4 volts. Certainly it will never fully charge. Charging voltages are in the 13-15 volt range and need to be tapered down as the battery charges.
I can put enough charge in my 2 100 amp batteries to be quite useful in about 3 hours using the generator. I do not think they get "totally" charged until I plug the trailer in overnight.
Nice generator, I expect. I have a 12 year old 2000 that still does a good job. But the 2200 is the one to buy now that they are out.
I have heard of people charging directly from the 12 volts on the generator but have never seen a clear reason for why they do it that way.
Old 12-17-2018, 03:14 PM   #6
AirMiles's Avatar
I believe the OP is asking how long it would take to charge an 84AH battery, resting at 12.4V, with a electric generator connected to the Airstream's shore power cord.
Old 12-17-2018, 03:50 PM   #7
1988 25' Excella
1987 32' Excella
My mistake. My reading skills were not sufficient. I apologize.
I do not know how long to fully charge but 3 hours gives a significantly useful improvement in charge when you are boon docking.
Wish I could go back and delete answer above but cannot. I thought he meant that he was direct charging from the gen at 12.4 volts charge voltage.
Old 12-17-2018, 04:04 PM   #8
AirMiles's Avatar
No worries Bill, I made a mistake in my post above too that I can't fix. I said the PD4655 has a 14.4V Bulk stage. Actually, Bulking occurs until 14.4V is reached and then the absorption stage begins. My wife and I have an agreement to not nag each-other over "senior" moments. Sadly, there is no such agreement on the Internet. I didn't mean to nag, I just wanted to redirect this thread back to the original question.
Old 12-18-2018, 08:47 AM   #9
We currently recharge the single battery each day with an 80 watt solar panel. On a sunny summer day it takes about 5 hours to bring the battery back up to full charge. I was wanting the 2200i generator for cooler cloudy weather when days are shorter and the heater may have to be in use. Maybe use the microwave too. Just wondering about charging time for the generator.
Old 12-18-2018, 09:58 AM   #10
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
It shouldn't take any longer than it does on shore power...ours is within 1/2hr, depending on SOC.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Generators . . . again? dinoburb Generators & Solar Power 6 03-18-2008 08:36 PM
Generators PeterH-Airstreamer Airstream Motorhome Forums 25 09-07-2004 10:46 AM
Generators csimingt 1999 Safari 11 07-26-2004 09:38 PM
Solar and Generators Melvin P. Thorpe Generators & Solar Power 43 05-11-2003 09:51 AM
Generators...one more time! APB Electrical - Systems, Generators, Batteries & Solar 0 03-09-2003 09:52 PM
