Old 07-03-2019, 01:48 PM   #1
1985 32.5' Airstream 325
Calgary , Alberta
Generator Help
I inherited a 1985 Airstream 325 from my father, and I don't know too much about it. The generator was running, but has recently been unable to fire up.
It will crank over, but won't start. I have checked the oil level, it's good. I've tried to start it with the coach engine running, but no luck. The batteries all have good charge.
I prime the engine for about 10 seconds and, at when I first hit the start button, it sounds like it wants to start but then settles into the sound of the starter cranking.
Yesterday, I tried again and heard an awful metal-on-metal high pitched sound when I hit the start button. The only thing I can compare it to is when the teeth on a car starter are not lined up with the flywheel and it grinds. It did that twice, then the third time it cranked like usual.
I removed the air filter to make sure it was clean, and it is.
Any suggestions before I take it to the local RV repair place? I'll be putting it up for sale soon, so I'd like to get the generator running.
Thanks in advance for any help.
jimbro is offline   Reply With Quote
Old 07-04-2019, 02:41 PM   #2
Chelsea , Maine
Gummed up carburetor is a common problem...
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 07-04-2019, 05:31 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Gas or diesel or propane? If it is a gasoline engine I would try 1 time removing the air filter and giving it a shot of starting fluid through the intake. I would have a fire extinguisher handy and have it parked away from the house while working on it.
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Propane Generator Help Please Snadi LP Gas, Piping, Tanks & Regulators 11 09-25-2005 05:03 PM
Never used a generator before- need help?? John Generators & Solar Power 13 04-12-2005 04:39 PM
help! what size generator?? tjj's63 Our Community 5 08-20-2003 07:33 PM
