Old 03-12-2007, 10:00 PM   #1
philippes's Avatar
1994 36' Classic 36
Cincinnati , Ohio
GE patio light H12 sealed beam
I have a Classic 36' 1994 Motorhome.
Do you know what is the right light used after the main door, at the compartment level. It is a GE H12, rectangular, Sealed beam with two pins in the back and unfortunately no reference. I have asked to many accessories dealer and they cannot find the right model. Where can I find it?
Thank you in advance for your help.
Philip
philippes is offline   Reply With Quote
Old 03-13-2007, 12:58 AM   #2
1992 34' Limited
Falls Church , Virginia
phiip -
I think that you can easily use the LED technology to power ALL the key points where other lighting was used, to were you went for interiour wattage. LED can do what it is cheaper/ and cooler/ and more efficiaently it was SO MUCH lower that any other contendor..... bar non. Compare watts/ amp-hrs and there is NO comparaison. LED ALL THE WAY!
Send specifics about the situatuon and "photos" whereEVER possible. Photos help when pages and pages of description doesn't do (DK) - all??????
Philip
SilverToy is offline   Reply With Quote
Old 03-13-2007, 06:11 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
I agaree with ST about going LED, but IIRC, you can find these at NAPA. The big Prevost busses use that same light in the entry doors to illuminate the area just outside.
Old 03-17-2007, 08:20 PM   #4
philippes's Avatar
1994 36' Classic 36
Cincinnati , Ohio
I have found the genuine replacement part. Thanks fro help.
Philip
Outlet under sink, night light LI Pets Electrical - Systems, Generators, Batteries & Solar 5 09-24-2006 05:25 PM
Pilot light in Frig niftypkg Refrigerators 9 04-10-2005 12:04 PM
And a patio on the roof, yet! Pahaska Our Community 2 11-11-2002 12:38 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
