Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 01-30-2015, 09:36 AM   #1
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
GCFI Outlets with Integrated USB
Has anyone had experience replacing some of the existing outlets in their AS with these outlets that have integrated USB ports on them?
I'd like to install these in our AS, but I don't know that the wall depth is sufficient to flush mount this type of device. The one I've linked above looks pretty deep, but I'm wondering if there are other units out there with a shallower draw that would work in an AS.
Here's an example from Leviton on Amazon:
http://amzn.com/B00J3PMU4C
trekerboy is offline   Reply With Quote
Old 01-30-2015, 09:43 AM   #2
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
I looked at doing this but realized that buying a plugin surge protector with both plug outlets and usb was simpler and cheaper.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 01-30-2015, 09:52 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I installed one in the bedroom replacing the outlet in the nightstand because depth was not an issue. I agree that it is a concern with all of the outlets that are shallow.
larry
lsbrodsky is offline   Reply With Quote
Old 01-30-2015, 11:28 AM   #4
z , North Carolina
Yup
I'm with mojo. GE model found @ Wallyworld for less than 15 bones.
FishinHatteras is offline   Reply With Quote
Old 03-03-2015, 11:27 PM   #5
Danny Bell's Avatar
1966 28' Ambassador
Colville , Washington
If you do have a space issue, you can put on a box extension, plastic or metal for a couple of bucks, available at any hardware store. Yes, it will protrude out from the wall a little which might not be pleasing to your eye but it will solve your problem, cheap !
Danny Bell is offline   Reply With Quote
Old 03-04-2015, 04:49 AM   #6
Naples , Florida
Danny Bell has it right! But you also must place the 120VAC outlet into a wiring receptacle box, something like a short re-model box so that the connections are contained.
The 2" Airstream (and almost every other RV) wall thickness is too shallow for the box/outlet combination. If you limit the positioning to placement in cabinets or counters, you won't have the depth problem.
The back of these dal outlets are larger than most other types and take up almost all of the remodel boxes. I have done many placements, but all were in wood cabinets/night stands with available depth.
lewster
Leviton USB 120V Outlets KJRitchie 2006 - 2010 Classic (all lengths) 14 03-31-2016 08:03 PM
120 Volt outlets w/USB ports PA BAMBI II Electrical - Systems, Generators, Batteries & Solar 3 06-30-2014 05:52 AM
USB Input available with Audio/Video Upgrade package Wayward Audio, Video & TV 4 04-30-2013 05:39 PM
USB Modem using Verizon or AT&T networks zlee Computers, Internet & Satellite 10 04-04-2012 11:04 PM
USB Wireless Aircard Router tbro Computers, Internet & Satellite 27 10-12-2010 06:56 PM
