Old 08-25-2017, 06:59 PM   #71
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Originally Posted by Rocinante View Post
Still loving our propane-fired Honda EU 2000i Companion.
Who did you purchase it from? How much, and also will it run a 13,500 AC without the Micro Air Easy Start? I thought I read somewhere here that folks were running a single AC 13,500 without the Easy Start?
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 08-25-2017, 07:07 PM   #72
gypsydad's Avatar
Update
Originally Posted by gypsydad View Post
Thanks for the post and update, Airmiles! As for the QD on my AS in front, I thought I would run to town yesterday and just purchase a propane hose with male QD's on both ends, but our little Lincoln HW store does not stock. Now I am heading to Helena later today to Lows or HomeDepot and try to find one. I thought I would just plug mail QD into trailer and into Dual Fuel and go...are you saying you think I need to use an LP regulator inline with this configuration also? I thought the one on the AS line was all I would need? I will be camping at 6k altitude typically up here in Glacier area next week....
No luck with trying to jury-rig with hoses and connections I have with me connecting directly to the AS QD. I can not find female connections here in Banff area, so may have to wait till I get back to US next week. I thought someone mentioned you could get the right hose, connectors, regulator also on line somewhere? If so, can someone please post again. Portable 7# bottle is working with supplied regulator and short hose...
Old 08-26-2017, 06:38 AM   #73
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
GenConnex is where we bought it. Runs our AC fine, even in Eco mode, with EasyStart installed.
Rocinante is our 2014 International Signature 27FB
Old 08-26-2017, 07:17 AM   #74
Lakes Region , New Hampshire
GenConnex is the place to go
http://www.genconnexdirect.net/propane-fittings.htm
RandyNH is offline   Reply With Quote
Old 08-26-2017, 09:14 AM   #75
dasams's Avatar
Marin , California
Same set-up and it ran our 15,000 BTU AC when at sea level. But it did not work in Central Oregon for the eclipse. Elevation was 3,600 ft and pressure was 0.88 atm. Hence perhaps 12% power loss. YMMV, Dave
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 08-26-2017, 09:56 AM   #76
Rivet Slave
Rocinante's Avatar
To be fair, we have not experimented with this setup at higher elevations.
Old 08-27-2017, 02:18 PM   #77
GenConnex has high altitude orifices, up to 10,000ft for their setups, were you utilizing one of these?
Old 08-28-2017, 09:28 AM   #78
dasams's Avatar
Marin , California
AFAIK, I have the standard orifice and I was not aware that different sizes are available. Can they be easily changed in the field? If so, that would be great.
2018 FC 27 FB
2017 FC 25 RB Gone
Old 08-28-2017, 10:50 AM   #79
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Question LPG conversion.....
Have the conversions changed?
No mixture block?
I converted our Honda in 2007 with a US Carb dual fuel. It has a mixture adjustment, re-adjusts nicely for altitude.
PFC
but Iím the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-28-2017, 04:23 PM   #80
Question
Originally Posted by thiel View Post
Just wanted to chime in because power reduction figures are often misquoted:
-- On natural gas, there's approximately 15% power loss
-- On PROPANE there is only 1-2% loss in power. So ALMOST ZERO loss.
(I see people confusing this all the time.)
I'm still confusing it....
Power reductions of the engine, not the alternator...correct.
Seems to this OF, that as long as the generator is not near max load the alternator doesn't care what the engine is powered with.
Our 2000i spins fine powering the 1500w microwave...on lpg or petrol, exactly the same rpm' needed in either case.
The engine is a bit less efficient on lpg but it's never been maxed out trying.
PFC
RLC
Old 09-06-2017, 12:42 PM   #81
gypsydad's Avatar
No luck with GenConnex
Well, I called these guys, and was told since I have a Champion, not a Honda, it would be best to contact Champion directly or go to a propane shop and get custom hose. I called Champion, but hold time was 23 min, So, off I go today to local propane dealer... by the way, we used the Champion Dual Fuel with the 20lb propane bottle for 28 hours this past 2 weeks, and still had 4 lbs of fuel in the portable tank. Pretty efficient generator...
Old 09-11-2017, 08:51 PM   #82
That's disappointing, you should have just just spec'd out the hose you wanted without a mention of brand, they only do Honda. So to cover their butt they don't make them for champion. Did you check their hose page to see if there is one you can just direct order on line? Hopefully by this point you're all set though.
Old 09-11-2017, 08:55 PM   #83
On the 2000 I believe it's just a side cover removal and an small Allen wrench to swap out the orifice on the front of the carb
Old 09-12-2017, 08:55 AM   #84
gypsydad's Avatar
Yea, I am good to go for now. I will spend some more time when I get back to Austin, and eliminate a few "reducers" I had to get to make things all work...key now is it is working fine! Amazon has all the fittings...should have just bit the bullet and got them there in first place.
Propane Cooktop Stove, Propane Oven from 1971 Sovereign colleenkay Airstream Classifieds 0 09-14-2016 04:06 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 09:56 AM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 01:36 PM
Options for Converting Generator to Propane bhayden Generators & Solar Power 3 11-28-2006 01:40 PM
Propane Generator Help Please Snadi LP Gas, Piping, Tanks & Regulators 11 09-25-2005 06:03 PM
