Old 08-18-2017, 09:43 AM   #57
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Originally Posted by dznf0g View Post
I find that with 260 watts of solar (100 on roof and 160 portable) When I am on the open, gennies rarely come out. When in shade with minimal solar input, running one 2000 watt gennie for 1.5 hours through the iota 55 amp converter every other day is plenty. I have 2 group 29 interstates. This is of course with no a/c but running FFs for a few hours during evening.
Agree; our Champion 2000 works fine for charging when in tree shade with minimal use every couple-three days or so. I can get by without the convection/microwave use for sure. But, AC needed when we are back in TX next month while boon docking; thus the switch to the Champion Dual fuel. Nice little unit, albeit a little heavy to move around. Wheels and handle make it much easier than I expected. I will keep in back of my TV most of the time going forward, but nice to know I can still move it around if needed.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 08-18-2017, 10:23 AM   #58
Mollysdad's Avatar
Originally Posted by dont45 View Post
Attachment 289269I just saw this camper in NY with generator mounted on trailer tongue. Looks like a nice setup, probably with custom bracket.
There's a commercially made bracket. It can be used for bicycles, storage boxes, or generators. I'd be concerned about mounting 200 pounds above hitch due to metal fatigue. There's gotta be a bunch of vibration leading to cracking. Also, the Honda is exposed to the elements, including water thrown back from the TV tires.
https://www.rvupgradestore.com/Trail...F8227F5463A11B
Originally Posted by TravlinMan View Post
You're gonna see generators get less and less popular I think.
He was just improperly convinced he needed 30amps all day long.
If I need 30 amps all day, I'll check into a campground with power.
I don't see myself adding solar panels to the roof, although the folding unit outside your rig is appealing. (When it's not blazing hot)
Right now, my generator is not going away. I've never run it all day, usually in the morning and evening. The rest of the time I'm out and about.
However, those of you solar fans won't be stopping at WalMart for shopping and lunch, and deploying the solar array to run the air conditioner while you eat and relax.
Old 08-18-2017, 12:52 PM   #59
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question Watt's the output?
So..... the watts are less on Propane.
Only if the reduced power output of the,(lpg) 'engine' powering the alternator is enough to overload.....our 2000i dual fuel conversion has been good up to 1500w on both lpg and petrol.
I don't know if the alternator really cares much watts spinning it.
My sex life is like a Ferrari...
I don't have a Ferrari. 😘
“It’s a crooked piece of time that we live in….”
John Prine
"Tahawus"
Old 08-18-2017, 01:15 PM   #60
Long Island , New York
Watt?
Wattchit there . . .
Old 08-18-2017, 01:24 PM   #61
dznf0g's Avatar
Oswego , Illinois
Watt you guys talking about?
-Rich-
Old 08-18-2017, 02:38 PM   #62
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you don't mind a mechanical engineer's opinion, I'd be more concerned about the increased tongue weight if you used that generator bracket on an Airstream. A trailer frame is a tough piece of metal, and vibration from a dinky little generator like that isn't likely to cause problems with metal fatigue. Unless you had bad welds in the first place, in which case vibration from the generator would lead you to find the bad welds while the trailer is safely parked…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-18-2017, 04:05 PM   #63
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
If you tow with a truck, your choice (big LPG tank permanently mounted in bed). If you tow with an SUV, go LPG - no place to store gasoline (exceptions of course).
If you use battery power all the time, look very close at solar and bigger battery capacity.
If you have to have AC, look very close at your choice. Makes for a very sensitive decision. Big one vs small one with a soft start. Gas vs LPG. Quiet vs just a little bit louder. Expensive vs economy priced. Heavy vs light. Solar very expensive but possibly doable. Figure out what works for you.
If you seldom use battery power, but occasionally need a charge, get a generator and leave it at home when you don't need it.
Ain't it cool to have choices. Pat
Old 08-18-2017, 05:55 PM   #64
Mollysdad's Avatar
No. I worried about metal fatigue in the rack suspending 200+ pounds above the tanks.
I guess I didn't make myself clear.
I thought about added tongue weight, but that's somewhat offset by carrying the generator in the truck bed. The total weight is less by the weight of the bracket.
... vibration from a dinky little generator like that isn't likely to cause problems with metal fatigue.
A Honda eu3000is is dinky? Meet the folks who don't like it because they can't muscle it into the truck. 150 pounds with gas.
Old 08-18-2017, 06:10 PM   #65
Compared to the big commercial generators I dealt with when I worked for a living, anything you can move without a crane is dinky. Size is relative.
WBCCI #1105
TAC LA-4
Old 08-19-2017, 10:23 AM   #66
gypsydad's Avatar
Champion Dual Fuel report
I ordered a new Dual Fuel Champion 3400 from Amazon and it arrived last week. Finally unpacked and fired her up using a portable 5# propane bottle with the included regulator and hose for the 5 hour break in period. It started right up with the electric start and ran continuously with no issues. It was easy to move around using the folding handle and wheels. I ended up lifting it into the back of my Yamaha side by side UTV; says 95lbs weight, and I did not have any problem lifting it, which was a concern about moving it around initially. The handles and wheels make it easy to maneuver and lift. I used the UTV to carry the generator and propane bottle during break in period so I could take it over to my AS across the property. All electric in the AS worked as advertised, of course only one AC at a time. (Mateo of Micro Air advised me I would not need an Easy Start with this generator, and he was correct.) Independently, both AC's fired right away and the Champion did not bog down at all. Specs say 3060 starting watts and 2790 running watts on LPG. No more carrying gas in the bed of the truck. I will use the LP connection on front of the AS primarily. Easy to carry the extra 5# propane bottle when/if needed. At $1,053 delivered by Amazon, this is a great deal! So far, very happy!
Old 08-19-2017, 11:28 AM   #67
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
Question: How did you connect your Champion Dual Fuel Generator to your Airstream?
I've read that some people just make a hose to plug it in without the large fuel controller and adjust the fuel mix with the 1/4 turn shut off valve. But I feel you need to keep the fuel controller to adjust the fuel mix. It took me two attempts to make it work.
My first attempt was to just make a 10' extension hose with a male LP tank connection on one end and a female LP tank connection on the other. I just connected this extension hose between the AS propane tank and the hose that came with the generator with the fuel controller with the 2" high-to-low pressure regulator. This setup did not work. There was too much restriction through the double tank connectors, so occasionally the generator would fuel starve after a short run (60 seconds). This hose is not pictured since it didn't work.
My second attempt (see picture) was to connect directly to the AS quick disconnect. I removed the small 2" high-to-low propane regulator from the larger fuel controller. I obtained the fittings to connect the rubber hose directly to where the 2" regulator was removed. On the other end of the hose, I added the fittings to terminate the hose with a male compression fitting. Then I made two different options to connect to the male compression fitting.
Option 1) I added a female-to-female compression fitting, another male compression fitting and then the male quick disconnect fitting needed to connect to the AS quick disconnect port. With this option I run the generator from the AS quick disconnect port.
Option 2) I bought an standard LP gas grill replacement hose with a female compression fitting on one end and an LP tank regulator connection on the other. I can remove the female-to-female compression fitting from Option 1 and connect to this standard LP gas grill hose (the short one in the picture). With this option I run the generator from a standard propane bottle.
My second attempt has been working perfectly and is pictured here: http://www.airforums.com/forums/f42/...ml#post1996143
2017 Flying Cloud 25FB (Miles) 114 nights 20,769 miles
400W Solar, Blue Ox SwayPro, 16" Michelins
2016 Nissan Titan XD 5.0 Cummins Diesel 4x4 (Max)
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 08-20-2017, 09:07 AM   #68
2016 25' International
Deerfield , Massachusetts
Just wanted to chime in because power reduction figures are often misquoted:
-- On natural gas, there's approximately 15% power loss
-- On PROPANE there is only 1-2% loss in power. So ALMOST ZERO loss.
(I see people confusing this all the time.)
thiel is offline   Reply With Quote
Old 08-20-2017, 11:13 AM   #69
gypsydad's Avatar
Thanks for the post and update, Airmiles! As for the QD on my AS in front, I thought I would run to town yesterday and just purchase a propane hose with male QD's on both ends, but our little Lincoln HW store does not stock. Now I am heading to Helena later today to Lows or HomeDepot and try to find one. I thought I would just plug mail QD into trailer and into Dual Fuel and go...are you saying you think I need to use an LP regulator inline with this configuration also? I thought the one on the AS line was all I would need? I will be camping at 6k altitude typically up here in Glacier area next week....
Old 08-20-2017, 02:12 PM   #70
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Still loving our propane-fired Honda EU 2000i Companion.
Rocinante is our 2014 International Signature 27FB
Propane Cooktop Stove, Propane Oven from 1971 Sovereign colleenkay Airstream Classifieds 0 09-14-2016 03:06 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 12:36 PM
Options for Converting Generator to Propane bhayden Generators & Solar Power 3 11-28-2006 12:40 PM
Propane Generator Help Please Snadi LP Gas, Piping, Tanks & Regulators 11 09-25-2005 05:03 PM
