Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 02-27-2008, 07:07 PM   #1
NWOverlander
Profile:  1966 26' Overlander
Prosser , Washington
Galvanized Electric Boxes?
When I tore my interior out to redo, I discovered the outlets were all in shallow galvanized electric boxes.
They are all secure, attached with sheet metal screws.
I am installing all new wiring. Should I take these out and replace with plastic?
Getting ready to finish up the outlets tomorrow. Advice would be greatly appreciated!
Thanks!
NWOverlander is offline   Reply With Quote
Old 02-27-2008, 08:25 PM   #2
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Probably doesn't make any difference. If you're more comfortable with plastic, then by all means. But you'll have to use the thin boxes. A standard box won't fit in the shell.
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 02-27-2008, 11:45 PM   #3
NWOverlander
Thanks Zep.
I have no problem with the galvanized boxes, and they are the perfect depth, not extending too far past the wall.
I expected a lot more input on this one, but I will assume it is okay to proceed.
Thanks Zep for your reply.
Old 02-28-2008, 03:38 AM   #4
C Johnson
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
Hi there, I have plastic boxes in my 1965 Caravel. If you want to go with plastic they should have them at any decent RV store. I found some at Curtis Trailers here in Portland. I think the galvanised would be easier to work with. The screw holes tend to strip out easy in the plastic boxes.
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Blog Chris' World
My Pictures
C Johnson is offline   Reply With Quote
Old 02-28-2008, 08:09 AM   #5
NWOverlander
I agree.
The galvanized are more solid and easier to work with.
I think as long as I tape the outlets up real good before putting them in the box that I will avoid a hot skin. That was my only real worry.
They did an excellent job installing the boxes. You could probably stand on them and they wouldn't move.
Two Switch Boxes spat61 Land Yacht/Legacy Motorhomes 4 01-14-2008 07:35 AM
Battery and converter boxes? erock53 Batteries, Univolts, Converters & Inverters 2 05-05-2007 10:43 AM
Topper or boxes? Cracker Tow Vehicles 8 02-02-2004 08:52 AM
Plastic battery boxes ! 77caravaner Electrical - Systems, Generators, Batteries & Solar 1 10-07-2002 12:57 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
