Old 04-17-2009, 05:51 PM   #1
1982 28' Airstream 280
Buena Park , California
Fusible Links
What is the proper way to replace older fusible links?
From what I understand, sometime mid 80's they stopped making the ones I have.
Is a maxifuse recommended?
Do I cut off the dark rubbery piece?
How do I tell what size fuse I need?
From what I can tell a 10 guage wire connect to a fusible link, the rubbery spits into 2 10 gauge wire, those 2 wire connect with the rubbery part which is attached to the solenoid under the dog house near the alternator. The rubbery part has "16" on it.
kennytheecat is offline   Reply With Quote
Old 04-17-2009, 08:29 PM   #2
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
The black plastic thing, that you will cut off, might have another #that you cant see till you take it out. 10 wire is good for 30 amps, You can ues any in line fuse style that is the same amps as orignal. Never saw a 16 amp that could be the link's wire size. Solder connections are best.
Bibbs
bibbs is offline   Reply With Quote
Old 04-17-2009, 09:42 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Fuse links were generally used as a stop gap measure to keep the main harness from cooking. I haven’t replaced one in years so I might be a bit fuzzy on the details.
First you need to find out what took out the link. If you have access to a wiring diagram it should tell you what the rating should be and where it goes.
Remember that link wire is not the same as regular primary wire. It’s designed to melt. Regular wire will carry current long after the insulation has caught fire and ruined a complete harness. You should be able to feel the difference in the insulation and flexability.
Adding in-line fuses without knowing what the current consumer or producer is could be asking for trouble. In addition I’ve found in-line fuse holders don’t have the longevity your looking for.
We would cut off the plastic splice covers and old link. Cut the new link to about the same size and reconnect them with self-sealing heat shrink butt connectors. That was the function of the molded rubber pieces on the original.
Hope that helps you out. Find the cause first. The repair is simple.
Good luck,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Easier links to. . . maxandgeorgia Off Topic Forum 3 03-02-2007 10:58 AM
I like Quick Links dijer Forum Admin, News and Member Account Info 4 09-18-2006 10:12 PM
