Old 03-12-2016, 03:25 PM   #1
2000 30' Excella
Tucson , Arizona
Fuses,convertor
I have a 1990 Excella 25'.
Can someone tell me where the fuses & converter are?I have found the breakers in the back cabinet.
winston10 is offline   Reply With Quote
Old 03-12-2016, 03:41 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
On my 93, inside, under the front window. Circuit breakers not fuses.
Old 03-12-2016, 04:01 PM   #3
dougandlori's Avatar
2004 28' Classic
Fresno , California
My 25' 90 Excella had had circuit breakers behind the couch. Under the couch was the converter. If you have the original converter you should change it to a newer model. Your batteries will appreciate it.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 04-08-2016, 01:17 AM   #4
mumbai , Wisconsin
I have 93 and i have fuses and converters under the front window.
twinklerai is offline   Reply With Quote
Fuses, what fuses? safariuser Electrical - Systems, Generators, Batteries & Solar 8 04-06-2015 05:52 AM
New Progressive Dynamics convertor, AGM battery, and Pendant questions wacnstac Batteries, Univolts, Converters & Inverters 16 05-09-2007 09:12 PM
power convertor ifly4cal Electrical - Systems, Generators, Batteries & Solar 4 12-07-2005 08:40 AM
Convertor question - 2005 Classic Pappy 2001 - 2005 Classic 2 05-30-2005 09:42 PM
New power Convertor HOT! silverbullet Electrical - Systems, Generators, Batteries & Solar 4 09-24-2002 10:01 AM
