Old 05-21-2007, 04:12 PM   #1
ga501's Avatar
1956 26' Crusier Overlander
douglasville , Georgia
Fused Neutrals????
Hi everyone,
A quick question for all the gurus out there.
We got lucky with our '56 overlander (other than a few soft floor spots);
the electrical still works great (origonal wiring). I just didn't like the
origonal s-type fuses installed back then (under the bath sink) so I
finished the 110 vac change-over this past weekend by installing a
breaker panel in the closet near by. I was surprised to find the
factory fused the neutral wires, too!!
Was this for the same reason one fuses the battery ground??
Just curious.....
Name:	56 overlander-2.JPG
ID:	37688   Click image for larger version
Name:	56 overlander-1.JPG
ga501 is offline   Reply With Quote
Old 05-21-2007, 04:28 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Maybe it is some kind of fail safe system just in case you got your nuetral and hot reversed and then that fuse would blow when the current started between the hot nuetral and the trailer ground which is also connected to the trailer shell. It does not work if your trailer is not grounded to the earth thru the stabilizers or tongue jack post. I would leave the fuse in there because you never know what you are going to run into at the campsites. I have found over 5 with hot nuetrals over the last 12 years. I always carry a $5 polarity checker in the truck door pocket to plug in before I park the trailer.
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 07:20 PM
Rear air system compressor bkahler Mechanics Corner - Engines, Transmission & More... 14 05-15-2007 05:14 AM
Fused Neg. at panel?? Phil Gobie Electrical - Systems, Generators, Batteries & Solar 3 02-19-2007 05:59 AM
Fused Ground - Why is it there? Joe Z Electrical - Systems, Generators, Batteries & Solar 11 12-14-2006 03:56 AM
