11-13-2009, 10:20 PM
1960 26' Overlander
Everett
Fuse Size for Grover Air Pump
Can anyone provide the correct in-line fuse size for the original Grover #1393 Air Pump used in a 1960 Overlander? I believe the pump draws around 6 amps but need to know the proper fuse size as the in-line holder is empty. Thanks in advance.
11-13-2009, 10:31 PM
1963 22' Safari
2020 27' Globetrotter
State of
I can check for you tomorrow when we have light out if someone doesn't beat me to it.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
11-14-2009, 06:48 PM
1963 22' Safari
State of
opened the fuse holder this afternoon and there is a 20 amp fuse. Not sure if that is right, just what the PO had in there. Hope that helps
Scott & Megan
11-14-2009, 07:42 PM
Corona
The correct fuse is a 10 amp SLOW BLOW.
Make sure the fuse is a slow blow, since it takes surges without blowing.
11-14-2009, 08:29 PM
The instruction manual for mine says 20a.
11-14-2009, 08:41 PM
1963 22' Safari
State of
Wouldn't suppose you've scanned the whole manual by chance have you? If so would you be willing to post it? thanks!
Scott & Megan
11-14-2009, 09:01 PM
I lied.
It's not really a manual, it's a one pager.
11-14-2009, 09:23 PM
1963 22' Safari
State of
awesome thats great, mine's working, getting it cleaned up and reoiled, pressure regulator etc seems to be working great.
Scott & Megan
11-15-2009, 10:13 AM
1960 26' Overlander
Everett
Thanks all, and extra thanks to Markdoane for posting the drawing. That's really helpful. Appreciate everyone's help!
