Old 11-13-2009, 10:20 PM   #1
1960 26' Overlander
Everett , Washington
Fuse Size for Grover Air Pump
Can anyone provide the correct in-line fuse size for the original Grover #1393 Air Pump used in a 1960 Overlander? I believe the pump draws around 6 amps but need to know the proper fuse size as the in-line holder is empty. Thanks in advance.
glang58 is offline   Reply With Quote
Old 11-13-2009, 10:31 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I can check for you tomorrow when we have light out if someone doesn't beat me to it.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-14-2009, 06:48 PM   #3
goransons's Avatar
1963 22' Safari
opened the fuse holder this afternoon and there is a 20 amp fuse. Not sure if that is right, just what the PO had in there. Hope that helps
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 11-14-2009, 07:42 PM   #4
The correct fuse is a 10 amp SLOW BLOW.
Make sure the fuse is a slow blow, since it takes surges without blowing.
Old 11-14-2009, 08:29 PM   #5
Images: 59
The instruction manual for mine says 20a.
markdoane is online now   Reply With Quote
Old 11-14-2009, 08:41 PM   #6
goransons's Avatar
1963 22' Safari
Wouldn't suppose you've scanned the whole manual by chance have you? If so would you be willing to post it? thanks!
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 11-14-2009, 09:01 PM   #7
Images: 59
I lied.
It's not really a manual, it's a one pager.
Old 11-14-2009, 09:23 PM   #8
goransons's Avatar
1963 22' Safari
awesome thats great, mine's working, getting it cleaned up and reoiled, pressure regulator etc seems to be working great.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 11-15-2009, 10:13 AM   #9
1960 26' Overlander
Thanks all, and extra thanks to Markdoane for posting the drawing. That's really helpful. Appreciate everyone's help!
Tank pressure from grover air pump Ron Banks Fresh Water Systems 8 08-29-2009 06:20 AM
Grover air compressor oil? samb Plumbing - Systems & Fixtures 10 01-19-2007 10:07 PM
Water Pump - Fuse Amperage??? TroutStream Water Heaters, Filters & Pumps 1 12-03-2004 06:50 AM
Rear fuel pump fuse guy99 Mechanics Corner - Engines, Transmission & More... 2 10-07-2004 05:33 PM
Fuse size? working Electrical - Systems, Generators, Batteries & Solar 5 05-08-2003 10:11 PM
