Old 10-03-2019, 07:33 PM   #1
2016 20' Flying Cloud
Cocoa Beach , Florida
Fuse Replacement Confusion 2016 20ft FC
Greetings Air Stream Community,
I am fairly skillful in most projects - except any electrical. True confession that I basically shut down my entire house when repairing anything electrical. My electrical weakness extends to the type, amperage, and number of fuses in our 2106 20ft. Flying Cloud. The manual lists approximately ten plus different fuse amperage and types (slow blow fuse, glass barrel, etc.) and trying to buy on-line is confusing.
Can anyone offer a list and simple explanation of fuse types to stock replacement fuses prior to our 6 week trip? I want to be prepared for the unexpected and avoid unanticipated surprises. i am also more than willing to read any suggested material.
As always, I appreciate your expertise.
Skip
Skip Stone is offline   Reply With Quote
Old 10-03-2019, 07:44 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Any of he fuses you are likely to blow are pretty standard automotive fuses. They are available just about anywhere you might be and for not a lot of money. Since you generally only blow fuses when poking around in wiring .... don't do that
If you have an inverter, there is a big fat, very expensive fuse involved. Best approach is to ignore it and move on. If you blow it, you won't be able to use the inverter. The most likely reason it would blow is that the inverter has melted down and you can't use it anymore ( = replacing the fuse would do no good).
If that does not give you enough security, then indeed head off to Amazon and start buying some of every fuse listed in the manual. ( or buy a bunch of fuse assortments and make sure they cover what you need). The numbers on the fuse type and the fuse current rating need to match up .
Puck or Surface Mount Replacement Confusion gabigirl General Repair Forum 5 08-31-2018 07:15 AM
Fuse Panel Confusion Profcbutler General Repair Forum 5 04-28-2018 08:49 AM
Replacing Univolt and 12V confusion sander17 Batteries, Univolts, Converters & Inverters 8 06-29-2004 09:09 AM
Wheel confusion Sneakinup Wheels, Hubs & Bearings 11 02-15-2004 09:22 PM
Confusion-1957 bubble parts smallfry General Interior Topics 5 11-21-2002 05:09 AM
