Old 09-07-2014, 09:49 AM   #1
2005 16' International CCD
Fuse Question
My 20 amp fuse popped and I've tried to replace it twice. Each time it blows out right away. Anyone know what I can do about that?
BambiBirder is offline   Reply With Quote
Old 09-07-2014, 12:55 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Purpose
Do you know what devices are on that particular circuit? If so, disconnect them and see if the fuse holds. If so, reconnect them one at a time. You could also use an ohm meter and look for the shorted device.
Old 09-07-2014, 03:20 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
if the circuit not noted as to what it covers on the panel you will have to disconnect Every Thing powered by 120 volts in the trailer. The convertor, the frig, the microwave, the TV, the hot water heater if it has an electric element, and anything else that is so powered.
Once all are disconnected attempt to turn on the breaker. If it still blows it could be a failed breaker, replace and try again. If it still blows there is a shorted wire somewhere in the trailer, not that likely, or something 120 volts is still connected, more likely. If it holds reconnect, one at a time all those items you disconnected. If the breaker blows it problem is with the last item you plugged in.
2004 Excursion 4x4
Old 09-07-2014, 06:31 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
12 or 120 volt?
The OP stated it is a problem with a fuse. I guess we need to know if it is a fuse or a circuit breaker. But he did say he replaced it twice and it blew. So I will assume it is on the 12 volt side of life and not the 120 volt.
Old 09-08-2014, 11:25 AM   #5
That's correct I'm going to have it checked at an RV place now. Thanks for the help.
Fuse panel question RandyG Batteries, Univolts, Converters & Inverters 2 06-10-2008 11:46 PM
345 Fuse question cajuncruiser Classic Motorhomes 12 01-31-2008 07:02 AM
fuse panel question BigSky Electrical - Systems, Generators, Batteries & Solar 6 02-26-2007 07:45 PM
Fuse size? working Electrical - Systems, Generators, Batteries & Solar 5 05-08-2003 10:11 PM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
