Old 04-16-2016, 02:59 PM   #1
1972 27' Overlander
Concord , North Carolina
Fuse Panel Replacement
I just replaced a 44 yr. old converter. I think I also need to replace the fuse panel. The problem is it's all old bus fuses and the new ones and even the new OEM ones don't hold the amperage that I need. 2 of the fuses are 30 amp each. Ideas??
solitairenc is offline   Reply With Quote
Old 04-16-2016, 03:04 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
There is not too much that can go wrong with a fuse panel. Why do you want to change it? If you replace it with a breaker panel you can get any configuration of ratings you want.
But back to the original question, why?
2004 Excursion 4x4
Old 04-16-2016, 05:14 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
fused panel
You can get 30 amp and larger fuse blocks. Type AGU 30 amp fuse block into the search engine. They come in single and multiple parallel fuse arrangements. I used them when redoing our '74 Argosy.
Old 04-16-2016, 05:35 PM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The fuse panel in those old trailers is part of the Univolt assembly.
Old 04-18-2016, 03:11 PM   #5
1972 27' Overlander
There are some dark areas in the fuse panel that require a little nudging sometimes to get them to work. I don't like nudging electricity. I will look at the panel website mentioned and see what I can find. Thanks. Yea my old univolt was humming like Hank Willaims Jr. on Jack Daniels.
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
12v fuse panel location? coldduc All Argosy Trailers 5 05-26-2004 06:15 PM
What size fuse for 12-volt panel? paddy79 Electrical - Systems, Generators, Batteries & Solar 4 05-23-2004 08:39 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
