Old 06-23-2004, 07:35 AM   #15
Andy, is that actual fuse any different from the one that goes in the hot (positive) side of the circuit - or are they identical fuses?
Patrick
Stagehand.
The 50 amp "ground" fuse was installed to protect the system in the event someone installed a battery backwards.
It's a good safety feature.
paddy79 is offline   Reply With Quote
Old 06-23-2004, 08:30 AM   #16
Paddy79.
That 50 amp fuse is "exactly" the same as the one in the charge line.
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
12v fuse panel location? coldduc All Argosy Trailers 5 05-26-2004 06:15 PM
What size fuse for 12-volt panel? paddy79 Electrical - Systems, Generators, Batteries & Solar 4 05-23-2004 08:39 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
