Old 05-17-2006, 04:01 PM   #1
1972 31' Sovereign
gig harbor , Washington
fuse help !!!!
hi everyone I need to know what amperage fuses to use in my 1972 sovereign 31. I cant even test the electrical and airstream arkansas says they dont know... too old.. thanks for all your help Shellie
Shellie is offline   Reply With Quote
Old 05-17-2006, 04:29 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Hi and welcome to the forums. Maybe someone will have a manual from this year that might have the specs....?
You might also try using the search tool (blue tool bar) and see what you turn up.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 05-17-2006, 05:46 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The two main (+ &-) fuses should be 50 amp glass fuses, the rest should be AGC 20, according to the slightly newer repair manual I have in front of me.
Old 05-17-2006, 06:24 PM   #4
The two main fuses are 50 amp.
The other fuses should all be 20 amp.
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
Voodoo in the fuse box! ralley Mechanics Corner - Engines, Transmission & More... 1 03-21-2006 07:52 PM
fuse burn outs Ed L Our Community 5 06-16-2003 10:10 PM
Fuse size? working Electrical - Systems, Generators, Batteries & Solar 5 05-08-2003 10:11 PM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
