Old 08-31-2014, 10:58 PM   #1
2012 25' FB Eddie Bauer
Longwood , Florida
fuse for running lights keeps blowing
I have a 2007 Basecamp and the fuse for the running lights seems to blow within a day or so of replacing it. There are very few visible wires to look for a short and I'm afraid there might be a short buried where I can't see it. Any ideas? It's been fine for years, now suddenly this occurs.
jeffdix is offline   Reply With Quote
Old 09-01-2014, 12:06 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Some ideas.
Hi, are you using the right sized fuse? Have you changed or repaired any trailer lights before this started to happen? Have you made any changes to your trailer where you have drilled a new hole or mounted anything with sheet metal screws? When I was fixing electrical systems on cars, the problem was almost always the last thing done to it before the problem started. [no matter how unrelated it may seem to you] Something as simple as replacing your license plate could have pinched the license light wire.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Generator 20 amp fuse keeps blowing jtsanchez Generators & Solar Power 6 02-13-2013 10:48 AM
dash light fuse keeps blowing buckeyechad General Motorhome Topics 20 10-22-2009 06:26 AM
power jack keeps blowing fuse? jlemmons Jacks, Stabilizers, Lifting and Leveling 6 08-01-2009 10:38 AM
Fuse #1 keeps blowing Z33 Electrical - Systems, Generators, Batteries & Solar 12 12-16-2006 08:43 AM
Brake Light fuse keeps blowing BW_LandYacht36MH Land Yacht/Legacy Motorhomes 3 08-25-2005 12:25 PM
