Old 02-28-2006, 11:50 AM   #1
acton
fuse box replacement on older airstream
anyone replace their old glass screw in fuse box with a newer breaker box? I have to do this on my 54 safari, any tips? What type of breaker box did you use etc?
Mitch
durans54 is offline   Reply With Quote
Old 02-28-2006, 01:01 PM   #2
Images: 59
Mitch,
I used a RV 50amp 240V breaker box from Progressive Dynamics that I bought from Randy at Bestconverter.com http://www.progressivedyn.prawnserve...?CategoryID=34
You probably want a 30amp/120V box. Those are available from the same place, but only as a combination box with 12V-dc fuse slots.
You can also buy a regular circuit breaker box at home depot, but I didn't find any that were the perfect size and capacity. If you do a 30a system you can only have five separate circuits, plus a main breaker, for a total of six spaces. You also need to separate the neutral and ground bars.
Old 02-28-2006, 03:31 PM   #3
ga501's Avatar
1956 26' Crusier Overlander
douglasville , Georgia
Hi Mitch,
I'm getting ready to do the same thing on my '56. The fuses are
under the bath 'vanity' screwed to the back wall. I found a panel
at home depot...it's made by Square D , rated at 70 amps, and has
8 circiut capability. I don't need all of them but this is the closest
I could find in 'panel size and it cost a lot less than what they
(dealers) want for a 30 amp model!!!! Let me know if you need some help and I'll walk you through the process.
Steve
ga501 is offline   Reply With Quote
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 10:20 PM
The Perfect Airstream miquael Airstream Motorhome Forums 4 10-02-2002 04:11 AM
Airstream T-Shirts jcanavera Our Community 15 08-15-2002 10:14 PM
replacement tail lights for '69 Airstream bgow 1969 Overlander 0 08-06-2002 10:03 PM
My plans for a neet Airstream FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-08-2002 01:30 AM
