Old 01-27-2008, 03:23 PM   #1
TSHEP
1978 25' Tradewind
1973 29' Ambassador
Woodlawn , Tennessee
Fuse Box
I am replacing Uni-Volt with Inteli-Power 9200 Converter in 73, 29th Ambassador, AS. Univolt is under the stove. I am going to build 3/4 plywood support to mount converter and fuse box. Where is the best place to get a fuse box? Do I need a 9 or 12 circuits fuse box?
TShep
TShepherd is offline   Reply With Quote
Old 01-27-2008, 04:20 PM   #2
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Hello Shep, 9 or 12 choose your fancy. I have a 9 with room to spare, Best Converter is where I bought mine. The search function here on this forum is very informative. Robert
bertro is offline   Reply With Quote
Old 01-27-2008, 04:53 PM   #3
Airstream 65's Avatar
1965 26' Overlander
2009 27' FB International
Winnipeg , Manitoba
Check out Vintage Trailer Supply - Vintage travel trailer parts and supplies! They seem to be running a special until the end of January. Get $25 off, or a free 12 position fuse box when you buy an Inteli-Power converter. Also, I got mine from Randy at BestConverter - Converters, Inverters, Electrical Supplies, Electronics, he gives good advice and has great service. Hope this helps.
Airstream 65 is offline   Reply With Quote
12 volt fuse box matilda Electrical - Systems, Generators, Batteries & Solar 2 06-27-2006 09:00 AM
Voodoo in the fuse box! ralley Mechanics Corner - Engines, Transmission & More... 1 03-21-2006 07:52 PM
Fuse box in '86 25' Sovereign? davidz71 Electrical - Systems, Generators, Batteries & Solar 8 01-11-2006 03:46 PM
Fuse Box?? dye904 Electrical - Systems, Generators, Batteries & Solar 4 10-27-2005 12:48 PM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
