Old 12-24-2018, 04:04 PM   #1
1978 31' Sovereign
Elk Mound , Wisconsin
Fuse Block Upgrade
Greetings all;
I am considering upgrading the fuse panel of my 78 Sovereign 31 Ft from the glass tube type fuses to the spade type automotive fuses. Of course the whole block would need to be replaced.
Has anyone done this before? What products do you recommend? What pitfalls did you run into? What changes did you make?
If figure it is better to learn from those who have walked this path before!
Thanks for the input.
Jim G
DrJimmy is offline   Reply With Quote
Old 12-24-2018, 04:29 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Personally, I like the cartridge types as you can tell at a glance if the fuse is blown. My second choice would be non resetting thermal breakers.
Old 12-24-2018, 08:02 PM   #3
2017 27' International
Lake Havasu City , Arizona
I don't like fuses, so I went with Blue Sea marine breaker panels.
It's easy to see when a breaker has tripped (each one has a pilot light), I don't have to worry about spare fuses, and a flip of the fingers turns off a circuit for troubleshooting or upgrade work.
Also, all connections to these panels are made with ring terminals (secured with lockwashers), rather than the setscrew terminals found in most RV electrical gear. Ring terminals are much less likely to loosen up during travel. A loose setscrew terminal can cause a literal meltdown or even a fire--I've seen it happen.
As you can see, I also replaced all the AC breakers, and replaced the converter's failure-prone automatic transfer switch (ATS) with a dual-breaker lockout pair. Yes, it's manual... but it's much less likely to fail than an ATS relay. Again, I've seen those go bad more than once.
These are not the cheapest ways to do things, but they are arguably the most reliable.
Paprika is offline   Reply With Quote
Old 12-25-2018, 07:15 AM   #4
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 119
I used standard automotive fuse blocks for the interior 12v circuits, and also bought high end car audio ANL fuse blocks as well. It was pretty simple to rewire. 5 years of use, and everything still works perfectly.
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is online now   Reply With Quote
Old 12-25-2018, 08:34 AM   #5
1978 31' Sovereign
From DrJ--I like that set up! Neat and tiddy."
Old 12-25-2018, 08:38 AM   #6
Fort Davis , Texas
I'm with Paprika on this one. Marine panels aren't cheap, but IMO are the best way to go. Below are my Blue Seas AC and DC panels.
Pat
ID:	330335   Click image for larger version
pdavitt is offline   Reply With Quote
Old 12-25-2018, 04:34 PM   #7
1978 31' Sovereign
Single breakers
I found some single breakers (stand alone units) on Amazon from MonkeyJack and from Kumeed. They are inline units, and I figure those would work great for the running light circuits. The ad says they are used for car stereos, but I figure a 15 amp breaker is a 15 amp breaker, as long as it is for 12 VDC.
I am planning to make a panel with all the needed breakers (15 amp, 20 amp, and 50 amp) and mount it in the Dinette base next to the door. This will make it much more accessible.
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
replace and upgrade converter fuse block nikiarntz113 Batteries, Univolts, Converters & Inverters 3 11-28-2010 09:24 AM
Fuse Block philippes Classic Motorhomes 6 09-26-2007 08:40 PM
Fuse block driving me nuts! bkahler Mechanics Corner - Engines, Transmission & More... 11 07-08-2007 08:52 PM
Fuse Block replacement - help Craig Electrical - Systems, Generators, Batteries & Solar 6 10-13-2004 03:01 PM
