Originally Posted by 77Argo
Greetings everyone!
I am in the process of replacing my 7 pin Tow Vehicle cable and some of the wires connect to a fuse block that has wires that return to the rear and are connected to the old univolt fuse panel near the Univolt. My question is there a diagram anyone is aware of for this so that unmake the correct connections?? I have an owners manual but it doesn't cover this fuse block..
Appreciate any guidance!!
I ran a new fuse 7 pin fuse connection and replaced the old connector. The 7 pin wires are in front, and the
12 volt wires, pink, yellow, and purple are in back near your old battery box. Of course the white is ground. I haven't seen a good diagram of the wires yet. My suggestion is to take the old Univolt system out.
