Old 10-11-2004, 05:07 PM   #1
1962 19' Globetrotter
2001 31' Excella
Fuse Block replacement - help
It looks like I need to replace the fuse block the powers the 12V interior lights, fans, etc. The block has five 20A fuses and one 50A fuse where the power from the battery and univolt come in to power the block.
Has anyone had to replace this? Will I need to fabricate something or purchase something to accomodate both the 20A and 50A fuses???
Any help would be greatly appreciated!!!
Craig is offline   Reply With Quote
Old 10-11-2004, 08:00 PM   #2
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Craig,
Try NAPA or AutoZone they have a lot of this stuff in the "electrical aisle". If you really need something special www.jcwhitney.com, www.jegs.com or www.summitracing.com have all kind of fuse bocks.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 10-11-2004, 08:43 PM   #3
Images: 59
If you want to go 'First Class', try these: http://www.bluesea.com/dept.asp?d_id...1=7958&l2=6609
Available from West Marine or BoatUS
Old 10-12-2004, 07:57 PM   #4
till's Avatar
Lisle , Illinois
Images: 108
Don,
Which one would you recomend?? I have to start some where for my DC curcuits
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 10-13-2004, 10:04 AM   #5
emanon25's Avatar
don-
looking at the distribution fuse blocks from blue sea i see some problems.
1> not rated for 50A
2> it's unclear if the connections for the wiring are substantial enough. they should accomodate at least #6 wire and be of the clamping type so as to avoid failure-prone crimp on connectors.
3> no gold plating, a serious benefit
look at these:
http://www.cardomain.com/shoplist~b~...ibution+Blocks
emanon
emanon25 is offline   Reply With Quote
Old 10-13-2004, 02:12 PM   #6
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I built a new fuse box into a plastic project box from radio shack. I also kept the ground shunt from the univolt to keep my amp meter working on the main panel.
It has worked fine. Here is a photo of it:
You can see more of description at my website here.
-Tim
theVAP - Airstream Podcast
Old 10-13-2004, 03:01 PM   #7
Images: 59
Originally Posted by till
Don,
Tedd,
I would start with the 50a fuse block http://www.bluesea.com/product.asp?P...1=7958&l2=6609 for the feed buss, then feed the distribution fuse block from that. Depends on whether you want to use the glass tube type fuses, or the blade style, and whether you want to stick with five/six circuits or provide expansion and go with twelve slots. I really like the ability to label the fuse positions (make your own, or buy from bluesea, they have hundreds), and I would definitely get one with a cover.
If you're really into it, do what Tim did. Nice box. See his website for lots of info
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
Final Floor Replacement Technique JohnG Repairing/Replacing Floor &/or Frame 46 01-15-2006 03:43 PM
'78 Tradewind labeled fuse box pics & questions BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 20 06-15-2005 06:33 PM
popping fuse on tow vehicle Stefrobrts Tow Vehicles 14 07-07-2004 01:43 PM
Fuse panel for 1-battery system paddy79 Electrical - Systems, Generators, Batteries & Solar 15 06-23-2004 08:30 AM
