Old 07-11-2015, 10:10 AM   #1
2013 25' FB Eddie Bauer
Phelps , New York
Angry Furrion Cables / Outlets
Has anyone else had problems with the Furrion power cable or the power inlets? We've got a 2013 Eddie Bauer 25'. Within 9 months the power on leds on both power inlets failed to light and shortly there after the indicator on the power cord failed. Since the nearest airstream dealer was 100 miles away I called airstream about a replacement cable. Their reply was you have to take it to a dealer to get a cable but it won't have the power on led any more. Two months later (February) we were in Tampa near a large Airstream dealer so I called the dealer, I was told that there was a new owner and the service department was closed and wouldn't be opened again for about six months. An airstream dealer with no service?
A week ago the site ground fault was tripped when I plugged in the power cable. The Furrion power cable had a leakage current in it. Bad cable, another make is fine.
I would think that if others are having the same problem Airstream would do something.
HCoover is offline   Reply With Quote
Old 07-11-2015, 10:50 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
There are quite a few posts on the Furrion LED failures. Typical RV trash. Get a Marinco cable.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-11-2015, 11:00 AM   #3
AWCHIEF's Avatar
2006 23' Safari SE
Biloxi , Mississippi
Images: 33
If and when mine ever craps out this is what I will be replacing it with,
Amazon.com : SmartPlug 30-Amp Inlet Charger Connector Combo Kit : Boating Battery Chargers : Sports & Outdoors
MICHAEL
Furrion 30A and TV inlet upgrade questions Bluto Electrical - Systems, Generators, Batteries & Solar 28 06-09-2016 08:31 PM
Furrion 30 AMP power inlet stainless steel svanpelt Airstream Classifieds 0 03-22-2015 01:52 PM
Furrion 30 amp Inlet Installation Tony S Electrical - Systems, Generators, Batteries & Solar 4 03-04-2014 12:05 PM
Furrion 30A TV inlet questions Tony S General Repair Forum 2 08-21-2013 11:13 AM
Furrion 30 amp cordsets on sale jmpratt Electrical - Systems, Generators, Batteries & Solar 0 04-02-2013 01:25 PM
