Old 01-24-2017, 05:03 PM   #1
2014 25' FB Flying Cloud
Oregon City , Oregon
Furrion 30 Amp Shore Power Inlet
Hello All-
The other day I broke the cover to our shore power inlet... I went to the local dealer and bought the replacement for $45. Of course I cant just replace the cover I need to replace the entire inlet.. My question is if anyone has done this before, according to step 11 in the instructions I need to tighten the terminal screws to 14-16 in-lbs torque. I went to a local hardware store as well as a local auto parts store and neither place carried a torque screwdriver. Is this a must or can I just tighten the terminal screws hand tight plus a little extra? Thanks for any input!
AZORCA is offline   Reply With Quote
Old 01-24-2017, 05:33 PM   #2
SailorSam205's Avatar
Northville , Michigan
I'm NOT an electrician, but my thought on this is, get the connection as tight as you can with your screwdriver. You don't want those wires coming loose. 14 inch/pounds is simply slightly higher than 1 foot pound. 12 inches = 1 foot!
Al
2017 26' SOB, 2018 F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 01-25-2017, 05:28 PM   #3
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
I just replaced my power inlets with the Smartplug and have kissed the plastic screw mess gooodby.
The Colonel is offline   Reply With Quote
Old 01-25-2017, 06:01 PM   #4
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
That is my next modification/upgrade, as soon as we get back from our trip this weekend. Replacing both power inlets and the cable/satellite one so they're all stainless steel.
SeaLevel is offline   Reply With Quote
Old 01-25-2017, 06:03 PM   #5
Navarre , Florida
The only thing I don't like is that smartplug doesn't make one for the cable tv cover. I've ordered the ss other one for now
The Colonel and Southern Belle
Old 01-25-2017, 07:15 PM   #6
Boxite's Avatar
2008 22' Sport
It might be helpful to know the average guy can place 35 ft-lbs of torque using a wrench with one hand, and 10 ft-lbs of torque twisting a screwdriver with one hand.
12 in-lbs is equivalent to one foot pound.
So, using one hand firmly tightening the screws should easily meet their recommendations. (But remember....just because a little-torque is good... doesn't mean a LOT of torque is better.)
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 01-25-2017, 07:30 PM   #7
Navarre , Florida
Good thing about the Smartplug is the connections are tightened with a hex wrench. Not sure there is a torque, I just tightened the heck out of them and all is well
Old 01-26-2017, 12:12 PM   #8
ericpeltier's Avatar
Superior , Colorado
I'd never heard of this product until this thread!
https://www.amazon.com/SmartPlug-BM3...s=smartplug+RV
Entertain me with why you like it better than the typical round plug?
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 01-26-2017, 12:15 PM   #9
Superior , Colorado
ooo-eee, those smartplug cords are SPENDY!
2012 Nissan Armada
Most of China
Old 01-26-2017, 02:26 PM   #10
Navarre , Florida
Got tired of screwing around (no pun intended) with the cheap plastic ring. Had to crank it down or shore side was loose. On cold mornings it was difficult to unscrew. The female side connections were already showing signs of wear. The blue light went out on the AS side receptacle and you can't change just the led. That presented enough encouragement to me to swap stuff out. The smartplug, albeit expensive is extremely well built and connects with a push of the plug. Disconnects remarkably easily with a squeeze of the side locks. I'm pleased but haven't put AS on the road with these yet. Next week will be real world test.
Old 01-26-2017, 02:28 PM   #11
Navarre , Florida
Oh, I got a female plug and turned my old cord into an extension cord
Old 01-26-2017, 04:04 PM   #12
1979 23' Safari
Wayland , New York
Had a similar install on a different product, similar torque requirements, said if no torque screwdriver available, snug plus 1/2 turn, snug being play taken out of pinch point.
Old 01-29-2017, 07:34 PM   #13
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Put any kind of a lubrication on the threads and the face of the screw, and you can really tighten it up. However....... It's easy to overtighten the screw and strip the threads. This idea is useful where stainless steel screws are hard to tighten, (High friction Factor), or the slot of the screw is damaged, and does not give much drive.
Basic idea? Seat the screw then 1/8th. of a turn. No more than a 1/4 for sure.
Oil is a good basic lube, grease is kinda extreme.
Look after your equipment, it will look after you. and.......
"Never eat more than you can lift." Miss piggy
MelGoddard is offline   Reply With Quote
Furrion 30 Amp Shore Power Inlet vincaroo Electrical - Systems, Generators, Batteries & Solar 15 01-15-2017 05:56 AM
Furrion Stainless Steel 30A inlet and TV inlet Gsmblue Electrical - Systems, Generators, Batteries & Solar 4 07-27-2015 06:58 PM
Furrion 30 Amp 125V Power Smart Inlet Spork Airstream Classifieds 0 04-20-2015 09:32 PM
Furrion 30 AMP power inlet stainless steel svanpelt Airstream Classifieds 0 03-22-2015 01:52 PM
Furrion 30 amp Inlet Installation Tony S Electrical - Systems, Generators, Batteries & Solar 4 03-04-2014 12:05 PM
