Old 03-01-2014, 04:59 PM   #1
1973 25' Tradewind
Beautiful , Oregon
Furrion 30 amp Inlet Installation
2.5 or 2.75 hole??
Hi Folks
About to install a Furrion 30a Inlet that I bought from Vintage Trailer Supply ( very nice) they say use a 2.5 hole saw for cut out in their on line instructions.
Furrion 30A Round Stainless Inlet
Furrions in box instructions says 2.75 hole saw. Which did you use?
I would like to use the smallest one that would do the job but you only get one shot with a hole saw without involved remedial measures. So is the safest way using a 2.75 hole saw and call it good?
Also please share any tips or advice or even a step by step you took to a successful installation.
Many thanks
Tony
Tony S is offline   Reply With Quote
Old 03-01-2014, 05:05 PM   #2
aquinob's Avatar
Portsmouth , Virginia
Have you measured the diameter at the widest part on the backside of the inlet? That would be the diameter that I would cut. I would make the hole as small as possible.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 03-01-2014, 08:02 PM   #3
1973 25' Tradewind
Beautiful , Oregon
Thanks no I haven't. I did drill a 2.5 piece of cardboard and it dropped in but then there is the plastic something or other. The trouble is until I do it I don't know what is going on. I don't want to over look something to find the hole doesn't fit.
Anyway I hope someone remembers what they did.
Tony
Old 03-01-2014, 09:20 PM   #4
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
If in doubt use a scrap piece of aluminum to figure out the hole issue. I also cut a rubber washer to help seal the housing to the shell and caulked both sides during assy. The whole thing was about an hours worth of time.
goshawks00 is offline   Reply With Quote
Old 03-04-2014, 12:05 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
you can use foamboard or cardboard to check. I drew a ring around mine, cut the hole and was fine. If in doubt you can start with a slightly smaller hole then file it out.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
Furrion 30A and TV inlet upgrade questions Bluto Electrical - Systems, Generators, Batteries & Solar 28 06-09-2016 08:31 PM
30 amp cord to 50 amp outlet. urnmor Batteries, Univolts, Converters & Inverters 20 10-21-2011 12:55 PM
30 amp to 50 amp ALANSD Electrical - Systems, Generators, Batteries & Solar 7 10-13-2011 04:59 PM
Question on using 50 amp sevice RLS Electrical - Systems, Generators, Batteries & Solar 16 02-04-2011 01:14 PM
