Old 08-24-2005, 12:03 PM   #1
Images: 8
full-time AC questions
Hello,
I've only had my AS for a month, and I am currently at a park with a full hook-up and have no tow vehicle. I like the location, so I won't be moving for the foreseeable future. I have a 79 Excella 500, 31', and am wondering what (if anything) I should do with the batteries/12 volt system. It seems like my meter is showing excessive energy use when I have nothing at all turned on besides the digital clock... I wonder if it could be related to charging batteries that I will not be needing, univolt, or ??? Should I simply disconnect the 2 (brand new) batteries? And then charge them every month or so?
Kinder is offline   Reply With Quote
Old 08-24-2005, 12:41 PM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I would install..
...an AC cut off switch for your univolt charger. You'll boil your batteries dry if you don't. You need them for your 12 volt lights, fans, detectors, etc...
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-24-2005, 05:27 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Some folks use a simple plug-in timer, with their Univolt hooked up to it. They set the timer so that the Univolt runs for 30 minutes or so a day, if the batteries seem to be slowly discharging, extend the time a bit.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 08-24-2005, 06:58 PM   #4
infinite LUX's Avatar
it took me a couple of weeks to figure out that the "buzz" of the charger could easily be turned off with the switch on the wall, on the right side of the front couch.
infinite LUX is offline   Reply With Quote
Old 08-24-2005, 07:24 PM   #5
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I always leave my Univolt on. Just check the batteries every 2 weeks for water, more often during hot weather.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-24-2005, 07:45 PM   #6
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Kinder,
I leave my Univolt on all the time, but I only check the batteries once per month. The older one has some trash floating in it now, but it's still got 2.2V differential between all the cells, so it's not a goner yet.
If you LIVE in the trailer, I think that the normal course of using the lights, fans, and other 12V appliances is enough to keep the Univolt from killing the baterries. Please do be sure that you only put distilled water in your batteries. (I think some tap water contributed to my dirty battery fluid, but that was before I owned it, and it came from the frigid north, so I'm not sure what effect extreme cold has on batteries.)
I'm curious -- where and how are you measuring the energy usage?
I'm sure somebody with more knowledge will chip in here, but I think you need to keep your batteries in the circuit. They "smooth out" the power from the Univolt. I know from my Argosy that if you run the Univolt without a battery, you end up replacing a LOT of light bulbs.
Hey, you have two brand new batteries? Great. I'd be trying to take care of them and prolong their life as long as possible.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-27-2005, 03:15 PM   #7
Images: 8
Thanks for the tips. I really like the idea of just topping off the batteries every couple weeks as I do indeed live full-time in it and run the fans and lights for a few hours each day. I measure energy use simply by the KW on the meter outside. Yep, brand new batteries.
I'll have to look for this switch to minimize the buzzing, although it is not noticeable when the univolt is hidden by the access panel. Not sure my AS has anything there beyond the exterior light switches.
On a mildly related note, how efficient are the bulbs do you think? I would love to replace them with LEDs or ?? as they do get pretty warm as I read at night. Any sources for something that specialized + little?
Airstream Labyrinth / Time limit on Post Composition ?? hex Forum Admin, News and Member Account Info 5 09-20-2002 02:27 PM
Airstream/Argosy Floorplans? Questions from a newbie ErichC Airstream Motorhome Forums 12 07-07-2002 10:29 PM
General Engine questions from a newbie ErichC Mechanics Corner - Engines, Transmission & More... 1 07-07-2002 05:23 PM
Questions on riveting technique 74Tradewind Ribs, Skins & Rivets 6 05-24-2002 09:45 PM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 07:21 PM
