Old 08-30-2014, 09:35 AM   #1
Midlothian , Texas
Front shore power connection
When shore power is plugged into the front receptacle, there is no alternating current power inside. When shore power is plugged into the rear receptacle, everything works fine? No breakers are flipped in either case. Any troubleshooting ideas? Thanks!
Daveark is offline   Reply With Quote
Old 08-30-2014, 10:06 AM   #2
Images: 59
Possible the front connection is for a generator and there is a transfer switch buried somewhere?
Old 08-30-2014, 10:13 AM   #3
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Bad transfer switch.
Al - K4GLU is offline   Reply With Quote
Old 08-30-2014, 10:32 AM   #4
1974 Argosy 20
Kooskia , Idaho
From what I understand, the AS original transfer switch is a very bad one, and fails often. I am sure it is your problem. <2 years old? Factory warrantee issue.
Old 08-30-2014, 01:08 PM   #5
Midlothian , Texas
Thanks much for the replies.
If it were the transfer switch wouldn't it have rendered both shore power connect points ineffective? The rear connection was still working fine.
I pulled the front receptacle, disconnected wiring, checked for any heating or shorting. Nothing. Put it back together and voila, power.
I am not totally convinced that it was a loose wire yet. Will see if there is a recurrence of the issue.
Old 08-30-2014, 01:36 PM   #6
1974 Argosy 20
Kooskia , Idaho
The transfer switch is basically a relay with a time delay system on most of them. When power is applied to the alternative input (front in this case) the time delay senses power, and in about 30 seconds the relay is activated to switch the input from the rear to the front source.
If the delay does not work, no switching occurs but the back input still works. If the relay does not work, same thing, it stays connected to the rear input.
So, no idea why yours is now working, but lets hope it remains that way. i don't have the system on my trailer, but understand the quality of the transfer switch system AS uses is less than great.
Old 08-30-2014, 02:26 PM   #7
daveswenson's Avatar
2012 28' International
Issaquah , Washington
You haven't mentioned year and model of your trailer, but in mine the transfer switch is attached to the back of the Parallax power center. Mine doesn't have a time delay, it's just a relay. My guess is yours has failed. If you need to replace it, this one is supposed to be better.
PD 5100 30 Amp Transfer Relay
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-30-2014, 05:59 PM   #8
BAB
BAB's Avatar
2015 30' Classic
Greensboro , North Carolina
I have the same trailer as daveswenson....and because the trailer came with the cheap Chinese model, I opted to replace it with the PD5100 BEFORE it failed. A very easy install. (BTW, my A/S dealer was wondering when I would be bringing my trailer in for a replacement to the original!)
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-31-2014, 07:15 AM   #9
Midlothian , Texas
Our 30' Classic was manufactured September 2011.
Makes total sense. If it hasn't failed, it seems to be wonky with future failure a possibility. Will locate it and order a better quality replacement.
HELP?! On Shore Power, but lights dim, and power fades TGadaire Batteries, Univolts, Converters & Inverters 4 11-24-2012 05:18 PM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
