Old 05-03-2014, 09:06 PM   #1
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Fridge Vent and Fridge 12V DC wiring
Greetings
I looked and looked so to not recreate a thread on this but need to post to get an answer!
Does anyone know where the 12V DC power is, if any, in the fridge access panel area? When I bought the new fridge it mentioned being hooked up to 12vDC but my old fridge only had the 120V and LP hooked up from the factory so I left it off now realizing that it is that circuit that powers the auto switchover from AC to LP.
Now, I just purchased a fridge vent fan and want to install it but am not sure where to draw power from. Thanks.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 05-03-2014, 09:33 PM   #2
1974 Argosy 20
Kooskia , Idaho
Your 2006 should have had electronic ignition for the controls and gas ignition originally which required 12 volts at the compartment. Somehow could you have missed the connections when you made the switch? Sounds like you did put a new refrigerator in. There were very few refrigerators made in the 2000's that didn't need 12 volt power for the ignition circuits. Look again for the wires somewhere in the back access panel for the refrigerator.
12v
Wiring through the Fridge vent. HELP! Libo Generators & Solar Power 8 03-27-2013 07:07 AM
Can you vent a battery through the fridge vent? Mike&Ali Batteries, Univolts, Converters & Inverters 22 03-07-2011 09:06 PM
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Wiring Behind Fridge Vent - What's it for? Cos Electrical - Systems, Generators, Batteries & Solar 5 04-14-2008 11:01 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
