Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-18-2009, 11:15 PM   #1
Profile:  2007 19' Bambi
Las Vegas , Nevada
Question Fridge Power question
Aaargh! We are going out tomorrow morning and would like our fridge cold when we start. Our dilemma:
We are plugged into a plug on our patio (110?) with an adapter.
The Fridge keeps clicking, trying to light the gas and the "check" light came on. We had propane off, thinking the house power was enough to run the fridge. Is it?
I turned on the propane thinking that I needed that to satisfy the attempted pilot lighting. Now the pilot is lit, the clicking has stopped.
I'm not sure the fridge is working off of our house electricity. I don't want to use up our propane.
Gastrolith
Gastrolith is offline   Reply With Quote
Old 07-18-2009, 11:30 PM   #2
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Airstream Registry
Few suggestions.
Hi, if your refrigerator is anything like mine, you may need to switch it to AC [120 volt] or Automatic. On Automatic, even with the propane turned on, it should automatically switch to AC voltage operation. I always turn my refrigerator "ON' first and then to "Automatic"
Do you have anything else [microwave] that you can turn on to verify that you actually have 120 volts AC working in your trailer and if so check for tripped circuit breakers.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 07-18-2009, 11:31 PM   #3
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 65
Airstream Registry
I wouldn't worry about using up propane - the fridge doesn't burn that much.
You should be able to run your fridge on a standard household circuit (at least if it's anything like mine).
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Old 07-19-2009, 01:04 AM   #4
Images: 18
Airstream Registry
Circuit tester.
Hi, one more thing that helps and is a good thing to keep plugged into one of your trailer's outlets is Circuit tester or polarity tester. If only the two yellow lights come on, that's a good start. This shows that you have power and that the system wired correctly. This is the first thing I look at when I plug my trailer in at a camp sight. My trailer came with one of these. If you don't have one, you should be able to buy one at any hardware store, for under $10.00.
2005 Safari 25-B
Old 07-19-2009, 11:08 AM   #5
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
Airstream Registry
Does your fridge need the battery on (12vdc ) in order to power the logic board on the fridge. If so the battery needs to be on also.
Aerowood is online now   Reply With Quote
Fridge and Microwave Question ???? tdoescher General Appliance Topics 1 04-14-2009 10:50 AM
dometic Fridge question goransons Refrigerators 5 07-24-2007 03:31 PM
Will fridge run without battery power? crazylev Refrigerators 9 09-01-2006 01:37 PM
New Fridge Not Working w/ AC Power Killo1 Refrigerators 17 08-03-2006 10:07 PM
Fridge power - gas/electric??? Tin Lizzy Refrigerators 7 05-10-2006 09:04 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
