Old 12-18-2006, 08:03 AM   #1
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
FM antenna
I don't see an FM radio antenna. There is an antenna wire connected to the radio and the wire goes up the wall but I don't see anything on top? The AS is a 77/31 Sovereign. I also have a Vanguard amplified ant. anyone using this for FM?
Phil Gobie is offline   Reply With Quote
Old 12-18-2006, 07:10 PM   #2
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Phil,
I can tell you about my two trailers.
The '75 Argosy 28 has a spring-coiled base whip in front on the street side and the wire runs under the skin behind the back of the curved front side window and up into the front overhead compartment.
The '79 Excella had an outlet inside the credenza. Both the stereo and the TV outlet were spliced into the overhead main TV antenna. On my front gaucho model, this is inside the credenza just aft of the stereo-8-track. A PO at some time removed the (trouble-prone) electrically actuated TV antenna and put a batwing style antenna on top. This is not tied into the stereo at all presently, so it ony picks up extremely strong signals. That's fairly low down on my list of things to fix as the old receiver picks up my XM Roady XT satellite receiver just fine. I like mixing 70's technology with 21st century technology.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 12-18-2006, 07:36 PM   #3
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
Lamar, Thanks for the info. I think I am going to try and connect to my amplified vanguard TV ant. We also use the Ipod and other inputs I just like to be able to pick up local stuff as well.
Old 12-23-2006, 09:00 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Phil, I had a '77 Excella 500 31' and the FM antenna was on the street side curved panel. I wonder if someone replaced the panel and didn't put the antenna back in.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-23-2006, 11:56 PM   #5
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
My moho has an external radio antenna which doubles as the CB radio antenna too. it really doesn't work well for the CB, but since I don't use the CB I don't care. The FM reception is good. I don't know if trailer set ups are the same.
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 12-24-2006, 09:35 AM   #6
New Borockton , Alabama
Images: 21
Phil,
I had a 76 Sov for awhile and I seem to remember it was integrated into the Skyliner antenna. I could be wrong but pretty sure it was up there.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 12-24-2006, 11:28 AM   #7
classic67's Avatar
2005 31' Classic
Hughsonville , New York
Astro, just be careful you don't damage the finals of your CB radio using a non-resonant antenna. It's best to use an antenna with the proper wavelength resonance for the frequencies you are utilizing.
Den
classic67 is offline   Reply With Quote
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Antenna connection PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 10-10-2002 03:15 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
