Old 09-20-2016, 07:35 AM   #29
John Geisen's Avatar
2005 28' International CCD
Palm Beach Gardens , Florida
Joe,
Yes, in previous posts I mentioned that I even ran a Commerical air compressor similar to the ones used at gas station (well, they used to use them) 😃 without a problem.
I ordered a new tester from the link you sent. It should be arriving tonight. I'll keep you in the loop with the results.
John
John Geisen is offline   Reply With Quote
Old 09-20-2016, 01:06 PM   #30
Shreveport , Louisiana
This should be downstream the trailer main breaker, but I once had an issue with my house breaker popping when plugging in the extension cord. The problem proved to be a burned out water heater AC element. I had left it on when draining the heater.
Endodoc is offline   Reply With Quote
Old 09-21-2016, 02:50 PM   #31
1979 23' Safari
Wayland , New York
John,
Sounds like it might be necessary to get into the breaker panel and take some readings on the individual circuits at this point. Obviously with power disconnected and breakers open, checking wiring on each individual breaker to figure out the bad circuit. Or open all breakers, connect trailer to gfci, close 30a breaker and leave closes. Then close and open each breaker one by one to find which breaker trips the gfci. Then figure out what is on that circuit.
Old 09-21-2016, 03:46 PM   #32
Joe,
I received the GFCI Tester. According to the tester the outlets inside the Airstream are all fine as is the GFCI outlet in the garage. When plugging the Airstream into the GFCI outlet it immediately trips just as before. Could it be the GFCI?
On a separate note, I had an electrician install a 30 amp RV box so I could run the air conditioner from time to time as well as other circuits inside the Airstream. All went well. It now seems the only problem I'm experiencing is using the GFCI. I'm torn between replacing it, since I don't believe replacing it will eliminate the problem, and pulling out the shore input socket and checking for proper neutral. Thoughts?
Old 09-21-2016, 03:47 PM   #33
That's interesting as well as a good reminder. Thanks.
John
Old 09-21-2016, 07:42 PM   #34
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
If the tester says the outlets are ok then you don't have a flipped neutral.
SuperTrouper is offline   Reply With Quote
Old 09-21-2016, 08:18 PM   #35
1979 23' Safari
Wayland , New York
Start the one breaker at a time method to figure out which branch circuit the issue is on. Then figure out what's on that circuit. Then we need to figure out what on that circuit could be bad.
Finding a short question HowieE Electrical - Systems, Generators, Batteries & Solar 14 09-07-2016 12:13 PM
Finding a short Stormy Weather Lights - Interior & Exterior 9 06-14-2011 07:49 AM
Short -Short Ramp Lights - Interior & Exterior 0 09-12-2007 04:34 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 01:41 PM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
