Old 03-22-2015, 04:32 PM   #1
2015 25' FB Flying Cloud
Georgetown , Texas
Fantastic Vent
We have our new AS (2015 Flying Cloud, 25' FB) out on its first extended camping trip. One small problem I've encountered is the operation of the Fantastic Vent. It has a button for the power lift of the dome, with a toggle for open or closed. The closed activation works fine, but I have to turn the knob manually to open. The switch does nothing to open it up. Has anyone else had this problem? Am I overlooking something? The so called manual (the one from Fantastic that is included in the documents) is almost worthless, especially since it describes a different model than the one I have. Thanks for your help.
GLovedahl is offline   Reply With Quote
Old 03-22-2015, 04:45 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hi - you need to be sure the knob is "locked" in to place (hard to describe) and then adjust the temp dials on the fan - I'm not near my trailer now but if you expect them to open and they don't, turn the temp dial 100% the other way. If you hear the motor spinning but nothing is opening, pull down on the manual knob and turn it clockwise until it sort of slides up and locks in. Wish I could explain that better. :-)
Good luck!
Old 03-23-2015, 09:34 AM   #3
daveswenson's Avatar
2012 28' International
Olympia , Washington
My first guess would be a bad switch, or a bad wiring connection. If it closes, then it's not the knob.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 04-01-2015, 12:02 PM   #4
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
We had one on our '99 Casita that had the rain sensor, It would close automatically if it sensed moisture. But if I remember correctly I had to open it manually .
I was a great feature that proved itself on the maiden trip. We had left the vent wide open and took off for a Durango Train ride when a thunder storm rolled through.
When we got back the vent was closed and all was dry inside
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
reverse switch on Fantastic Vent bradk Roof Vents, Skylights & Fans 19 07-12-2006 11:11 PM
Vent Covers Over Fantastic Fan flyfisher Roof Vents, Skylights & Fans 14 01-24-2006 03:02 PM
Fantastic Vent R&SZinser Roof Vents, Skylights & Fans 11 11-30-2005 07:56 AM
Fantastic Vent sticking 74Argosy24MH Roof Vents, Skylights & Fans 37 06-09-2005 05:15 AM
Which Fantastic Vent? uwe Roof Vents, Skylights & Fans 9 08-30-2004 09:37 AM
