07-11-2016, 10:39 PM
2008 19' Bambi
Lake Oswego
, Oregon
Fantastic Fan/Vent Malfunction?
I own a 25', '04 International CCD, with forward and aft ceiling fans/vents. The fans are not working and I've checked all of the fuses etc. and the manual info. is not helpful in terms of problem solving. They do not appear to be 'dirty' etc.. Is there a 'trick' to these fans, other than having the vents open at least 3"? Power seems to be getting to the Fans, given their millisecond start, but they don't continue. Thanks in advance for any feedback etc..
Barry
Trout Lake, Wa.
07-12-2016, 05:22 AM
Normal
I have found mine a bit tricky, as there are a couple of buttons and sometimes I have touched the wrong one.
If the rain sensors have turned it off, it sometimes requires a bit of fiddling to get it open again.
If you can hand crank it open, with the fan on, that will insure it is working.
Then find the proper switch for off, and it should retract itself and turn off the fan, then should work normally.
If you don't get the answer you need here, or are impatient , might Google fantastic fan and call their customer service. They are friendly and very helpful.
Take your phone out to your rig, be sure your battery is set to use, and they will walk you thru it.
Good luck.
Maggie
07-12-2016, 06:37 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Clean the topside pinswitches with an electrical cleaner. They tend to oxidize after getting wet.
07-13-2016, 10:29 AM
2008 19' Bambi
Lake Oswego
, Oregon
Pin Switches?
Thanks for the tip Atomic. Where are the pin switches? Do I remove the whole assembly from inside the Airstream, or work from the roof down?
Barry
07-13-2016, 10:36 AM
Overland Adventurer
2009 34' Panamerica
Telluride
No dont remove anything!
Open the vents all the way.
climb up to the vent and youll see a silver plunger type switch on the front inside edge. Give it a squirt of your favorite electronic or motor cleaner then a shot of penetrating oil. Exercise the switch a few times. Should cure your inop condition.
this should be a part of seasonal maintenance.
07-25-2016, 10:22 PM
2008 19' Bambi
Lake Oswego
, Oregon
Fans Dilemma
Thanks Atomic,
I'll try your suggestion(s) tomorrow.
Barry
07-26-2016, 04:17 AM
Normal
My fan quit yesterday afternoon, and I've noticed the red sensor light is off, so I'm hoping it is a fuse.
Looking at the fuse box, tho, nothing is labeled for the fan....anyone have any idea what the vent fan would be attached to?
Maggie
07-26-2016, 06:32 AM
Normal
I located and replaced the fuse , which is actually in the fan framework rather than the fuse box , but the blade is still not turning tho the cover opens when I flip the switch.
Have reset the switch, will try resetting everything after a bit and see what happens...
Maggie
07-26-2016, 06:51 AM
I'm In
, Kentucky
If the cover is opening then it's getting power. Mine has a thermostat, cuts off the fan when the temperature is reached. It's a knob that can be rotated from red to blue. Try turning that knob to one extreme or the other. If nothing happens then the motor may be burned out.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
07-26-2016, 07:03 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Have you cleaned the pin switch? This is the problem most of the time!
07-26-2016, 10:47 AM
2012 25' FB Flying Cloud
Parker
I've had the same issue. Fantastic Fan warranty is 7 years for all fans installed in Airstreams. Customer service has been very helpful, except for one problem - they won't send you a new fan. I've had them ship me on several occasions the following items.
1. motor
2. the pin switch
3. control board
4. Main on off switch
5. temperature switch
Only thing left is the rain sensor, I think I'll request that just for grins.
None of these made the fan turn on. I finally gave up and replaced with a Maxxfan Plus. 10 speed variable, much quieter, and came with a remote so I don't even have to get out of bed.
2012 25FB with solar
2012 Toyota Tundra 5.7L V8
07-26-2016, 01:31 PM
Normal
I've noticed the little sensor light is still not on, so something apparently is burned out.
I'm going to call their customer service and have them walk me thru a thorough check of everything.
I'll report back.
Maggie
07-26-2016, 02:41 PM
1966 22' Safari
Hilltop Lakes
I think the pin switch is like the button that turns off the light inside the fridge when the door is closed. Those can get stuck in the retracted position. Some here have suggested cleaning and lubricating this switch. See if you can find anything like that on the fan assembly--probably located so it tells the fan if the cover is open or closed.
At least that's what I'm getting from the discussion. Never saw one of these fans, so I'm just trying to re-state what others have said. Everyone feel free to correct me if I'm wrong.
07-26-2016, 08:02 PM
2015 27' Flying Cloud
Newberg
, Oregon
Does anyone know what the little red led light is for? Sometimes mine is flashing, sometimes it's steady. Why? I have no clue.
Mike
07-26-2016, 08:18 PM
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
Never saw that little light, my fan is working. So Atomic, I climb on roof to do pin maintainence? Gezznot sure how to do that as my ladder not that high.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
07-26-2016, 08:53 PM
1995 25' Excella
xxxxx
, xxxxxx
You can pop out the screen from inside the trailer and use a spray can extension to squirt the switch with cleaner and oil. You most likely can reach the plunger with a finger to move it. If not use a tool.
07-28-2016, 02:21 PM
Normal
Finally got around to calling Fantastic Fan...now owned by Dometic....a bit ago, and they were their usual excellent selves.
They told me the red light is on the circuit board, which can't be seen from below, and checking it requires getting on the roof.
There is a 7 year warranty, Sharon sent me an email confirming the coverage, and a repair place in Watertown, SD, will check it for me tomorrow.
Maggie
07-28-2016, 02:38 PM
Overland Adventurer
2009 34' Panamerica
Telluride
I suppose you could reach the pin by removi g the screen and rraching it from inside. My hands are too big to fit between the fan blades.
Im looking at my pin switch as I post this
07-28-2016, 02:55 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
I have had at lease 6 different Fantastic Fans, but none of them have had a red light. So, I'm curious about that. Do those with the red light have a remote control?
I just returned from a few days of camping, where one of my 17 year old Fantastic Fans no longer responds to changing the thermostat position. The fan runs whether the setting is at max hot or max cold. I assume it's the thermostat gone bad. Anyone had this problem?
Alan
07-28-2016, 03:04 PM
Normal
Sharon at FF told me the red light is on the circuit board, and began with the 2014 models, which is when ours was replaced. It has no remote control.
The red light on mine has not come back with the fuse replacement, so something is wrong there.
I tried to get the screen off, to look at that pin, but it didn't want to come off and I was afraid of breaking the screen framework.
I'll have them show me what and how to do that tomorrow.
Maggie
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
