Old 06-11-2015, 04:49 PM   #1
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
Fantastic Fan rain sensor location?
Where is the rain sensor for the Fantastic Fan? Is it the little brass or copper dealybob just below the fan blades but above the screen that looks like a firecracker? Or is it on the outside of the assembly somewhere?
I can't find a legible parts diagram on-line, and so I put the question to the forum. Thanks in advance.
brad1 is offline   Reply With Quote
Old 06-11-2015, 05:31 PM   #2
dznf0g's Avatar
Oswego , Illinois
Above in the corner. It looks like a circuit board sorta.
-Rich-
Old 06-11-2015, 05:32 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It is a 1/2"x2" or so strip on top of the base, under the lid. It is toward the end away from the hinge. It looks sort of like the defroster grid in your car's back window. There will be two black wires coming out of it, and running under the base. It is held in place with a clip and a single phillips screw.
Old 06-11-2015, 06:12 PM   #4
Loafy the Wonder-Sled
Tumbleweed61's Avatar
1986 25' Sovereign
Mercury , Nevada
The brass/copper dealybob is the thermostat sensor.
"The sting of having paid too much remains long after the veneer of newness has worn away."
'86 Sovereign 25'. Somewhere near Mercury, NV
Tumbleweed61 is offline   Reply With Quote
Old 06-11-2015, 07:13 PM   #5
Kevin245's Avatar
I thought the technical term was doohickey.
Eleanor Roosevelt
Old 06-11-2015, 08:06 PM   #6
Well Preserved
1993 21' Sovereign
Y'all are both wrong. It's clearly a thingamajig.
Old 06-11-2015, 08:09 PM   #7
dznf0g's Avatar
Oswego , Illinois
Kumbobulator
-Rich-
Old 06-11-2015, 08:25 PM   #8
1986 25' Sovereign
Mercury , Nevada
Wink
I generally prefer "hoober-doober", but I was merely quoting the source.
Old 06-12-2015, 06:46 AM   #9
dznf0g's Avatar
Oswego , Illinois
As I age, I find I use:
"whatchamacallit".....a bit more than I used too.
Hummm, I forget if that is the correct spelling.....
-Rich-
Old 06-12-2015, 07:05 AM   #10
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I agree it is a "whatchamacallit"
urnmor is offline   Reply With Quote
Old 06-12-2015, 07:26 AM   #11
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
How about widget or gizmo... fewer syllables and easier to spell!
Yes, I would call it a circuit board too. It does look similar to a defroster grid of sorts, but it's made with circuit board material, it's the thickness of a typical circuit board, if yours are like mine it's made of green fiberglass substrate the same as a circuit board.
I'm curious why you're asking about the rain sensor. Is yours not working? I've been told that you can "clean" them by using a pencil eraser to gently rub the dirt and residue from the circuit board "defroster" grid. You might try cleaning before you replace it. Either way, you have to get up on top of the trailer with the Fantastic Vent lid open so you can gain access.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 06-12-2015, 08:51 AM   #12
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
It's that green/copper strip, bottom right
2012 Dodge Durango Hemi/AWD
Old 06-12-2015, 11:57 AM   #13
Aptos , California
You folks are the best. For one thing, you speak my language .
Old 06-12-2015, 02:03 PM   #14
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Good photo by Wayne/Sam. Fantastic says to try cleaning before replacing. A little soap/water and clean with a rag, rinse, wipe dry. If you take the Screen out (just snaps in place), you can do it from inside the trailer with your finger through the blades. Mine has stopped working a couple of times and cleaning has fixed.
Howard L. is offline   Reply With Quote
Fantastic Fan - Rain Sensor Not Working jbroedlow Roof Vents, Skylights & Fans 6 05-15-2016 03:43 PM
Fantastic Fan Vent rain leak???? jvcolaizzi General Repair Forum 1 09-01-2014 11:26 AM
Rain, Rain, Rain knunut Off Topic Forum 12 01-10-2013 07:25 PM
Rain V. Walbernize - Rain Wins monkeypants Our Community 0 08-22-2009 08:18 AM
Rain, rain, go away... Twinkie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-29-2007 04:50 PM
