Old 06-12-2015, 02:21 PM   #15
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yup cleaning can help.
I just happened to remove that fan and take photos to sell it.
Timing is everything.
2012 Dodge Durango Hemi/AWD
Old 06-12-2015, 02:29 PM   #16
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Gizmo or Chingaso depending on country of origin
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 06-12-2015, 03:22 PM   #17
Kevin245's Avatar
Originally Posted by brad1 View Post
You folks are the best. For one thing, you speak my language .
Let us know when you need to check the turn signal or running light fluid levels.
You'll receive lots of sage advice.
Eleanor Roosevelt
Old 06-12-2015, 05:06 PM   #18
Loafy the Wonder-Sled
Tumbleweed61's Avatar
1986 25' Sovereign
Mercury , Nevada
This is true. And I will add that one of my favorite part suppliers is
KaleCo
I've been using them for years.
"The sting of having paid too much remains long after the veneer of newness has worn away."
'86 Sovereign 25'. Somewhere near Mercury, NV
Tumbleweed61 is offline   Reply With Quote
Old 06-13-2015, 09:29 AM   #19
Just a bit obsessed!!!
Ibenoverland's Avatar
1974 27' Overlander
1975 31' Sovereign
1965 26' Overlander
Charlotte , North Carolina
I am having trouble removing the screen I feel like I am going to break it. Does it turn and pop out?
Ibenoverland is offline   Reply With Quote
Old 06-13-2015, 10:04 AM   #20
Missouri Valley , Iowa
If you have the screen without screws there should be a finger pull area on the outside edge. Put your finger in it and pull down. They do pull hard sometimes.
Dan
Farmer Dan is offline   Reply With Quote
Old 06-13-2015, 06:52 PM   #21
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Also, while pulling down on that screen ring finger lip, use your other hand and try to push the outer ring, next to where you are pulling, inward. That will help take pressure off the molded clips that hold the ring in place. Once a clip or two are dislodged, the screen drops right out.
Howard L. is offline   Reply With Quote
Old 06-14-2015, 07:40 AM   #22
1974 27' Overlander
1975 31' Sovereign
1965 26' Overlander
Thanks got it I just don't want to break it.
Old 06-14-2015, 07:41 AM   #23
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
I installed the Fantastic Fan vent cover two days ago (Relatively easy installation). No concerns about the rain sensor chingaso any more.
>>ron<<
Old 07-27-2015, 10:57 AM   #24
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
My used 2009 25 Int. came with Fantastic Fans. I understand they have a rain sensor which is really a nice feature. Last night it rained and I had the fan cover open (AS was parked in drive way) and when I looked at it this morning it was open again. So I thought maybe it didn't close as if the sensor was not working. But there was not a drop of water inside.
So does it close when it senses water and then open again as soon as it is dry?
Old 07-27-2015, 11:02 AM   #25
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Yes, if it's working correctly.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 07-27-2015, 10:22 PM   #26
Howard L.'s Avatar
San Antonio , Texas
Originally Posted by Howard L. View Post
Good photo by Wayne/Sam. Fantastic says to try cleaning before replacing. A little soap/water and clean with a rag, rinse, wipe dry. If you take the Screen out (just snaps in place), you can do it from inside the trailer with your finger through the blades. Mine has stopped working a couple of times and cleaning has fixed.
Thought I would add: After cleaning the rain sensor a couple of times it has just about given up the ghost. Last night it did close in a rain, but not until it was pouring and the floor was already quite wet. It also tried to re-open while it was still raining. Guess its time to change out the sensor. Fantastic will send a new sensor and instructions for the repair. Think i'll order a spare to have on hand also.
Fantastic Fan - Rain Sensor Not Working jbroedlow Roof Vents, Skylights & Fans 6 05-15-2016 03:43 PM
Fantastic Fan Vent rain leak???? jvcolaizzi General Repair Forum 1 09-01-2014 11:26 AM
Rain, Rain, Rain knunut Off Topic Forum 12 01-10-2013 07:25 PM
Rain V. Walbernize - Rain Wins monkeypants Our Community 0 08-22-2009 08:18 AM
Rain, rain, go away... Twinkie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-29-2007 04:50 PM
